diyAudio Sponsor
Old 9th January 2011, 07:22 PM   #1
jjman is offline jjman  United States
Default 12ax7: How to maximize output?
I'm using The Valve Wizard's load line calculator to try to determine how to configure a particular 12ax7 stage for max output and no clipping.
http://www.freewebs.com/valvewizard2...inePlotter.xls
I will bypass the cathode's resistor with a "large" cap or use LED bias. I have red LEDs that provide 1.6 and 1.7 volts but I'm not afraid to use a resistor and cap since I think "hotter" bias may be better for me (and it's a guitar amp.)
I have a 320V PS node available and I think the grid will see about 1Vp-p. I know that I should keep the bias point yielding at or under 1ma, and I guess I should probably keep the grid from reaching zero volts when driven. The total load I have on the output signal is probably around 200k.
It looks to me that a 200k Ra with a bias at about -1V would provide a plate swing from 95V to 170V for an output of 75Vpp. And a 300k Ra would swing the plate from 75V to 155V for a swing of 80Vpp. Higher value Ra doesn't appear to yield more swing potential. And a 100K Ra looks to yield about 60V swing when biasing below 1ma at around -2V.
This is the 1st time I’m really trying to use load lines. It appears to me I should use a Ra of 300k? Are there other considerations that would affect the ideal plate resistor considering my goal of maximizing the output signal? Is 300k just crazy?
Old 9th January 2011, 07:34 PM   #2
Svein_B is offline Svein_B  Norway
Your loadlines look good. 200-300K seem to be good values.
You could get a little more by using a CCS load for a flat loadline, and a gain of ~100.
When estimating the gain, you will however also need to consider the AC load represented by the next stage.
If you have a 500K gridleak on the next stage, you should draw a new AC loadline with the combined load (300K in parallel with 500K), centered on the operating point.
Svein.
Old 9th January 2011, 07:47 PM   #3
How the gain can become 100 when the mu of the tube is 100.
Does the CCS make the 12AX7's rp = zero ohms ?
Old 9th January 2011, 07:57 PM   #4
bigwill is offline bigwill  United Kingdom
The gain becomes 100 precisely because the Mu is 100. The Rp of the tube is unaffected (barring changes due to nonlinearity).
The tube can be thought of as a variable voltage source in series with its Rp with gain of Mu (or a variable current source in parallel with Rp, with its Gm that of the tube in question)
Old 9th January 2011, 08:04 PM   #5
...and the gain is still 100 when there is 500 kohms load as a grid leak of the next stage ?
Old 9th January 2011, 08:11 PM   #6
SY's Avatar
No.
For maximum swing, you want the next stage input Z to be as high as possible. Interposing a cathode follower might be worthwhile to squeeze out the most gain and bandwidth possible. The impedances are rather too high for effective use of a plate choke.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 9th January 2011, 08:32 PM   #7
Is it really necessary to try to wring as much voltage swing as possible out of a 12ax7 gain stage? What are you planning on driving with it?
Old 9th January 2011, 08:56 PM   #8
Thanx for the feedback.
It is a boosting stage after an “effects loop.” It’s then mixed back in with the “dry” signal path and I could use a little more than from its current configuration of a 100k and 252V on the current PS node. There are other approaches I could have used for the “mixing” but I’ve already gone way down the current configuration and just need a little more if possible.
It's output goes to a "mix" control which then goes on to a LTPI. Overall impedance from those is about 200k (without considering it's own plate resistor.) Exactly how do I "draw a new AC load line with the combined load (300K in parallel with 200K), centered on the operating point." ?
I think 300k||200k is about 125k but how do I "draw" that and use it? Do I use only this new line's slope and "slide" it onto the DC idle point? Or do I draw the 125k line in a normal fashion and do something else?
Will this change the ideal Ra value for me or does it just accuratize the projected output strength?
Old 9th January 2011, 10:00 PM   #9
Miles Prower's Avatar
You do it like this (attached). The normal DC Loadline comes in at:
Vpk= 120.62Vdc
Ipq= 0.59mA
The AC Loadline is based on the expected impedance, in this case: 144K. So figure the deltaI:
deltaI= 120.62 / 144E3= 0.84mA
Add that to the DC bias current: deltaI + Ipq
0.59 + 0.84= 1.43mA
Find that point along the vertical (plate current) axis, and draw the AC Loadline between that point and the Q-Point on the DC Loadline. Done.
It does change the Ra value completely so far as AC operation is concerned. Sometimes, it makes a difference, and sometimes it doesn't. (Inthis case, it made a big difference.) If the AC load is within +/- 5% of the DC plate load, I just ignore the difference. That's probably well within component tolerance, and hollow state is a good deal more "forgiving" than solid state design anyway.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 10th January 2011, 07:17 AM   #10
Bigwill, I did not get your answer yet.
How the gain of a 12AX7 can become 100 with CCS when there is 500 kohms grid leak of the following stage as a load ?
Aikido Phono Amp Output Tubes 12AU7 and 12AX7? JustinJ Tubes / Valves 28 17th August 2010 02:42 PM
Spike locations to maximize loading? ro9397 Multi-Way 2 15th June 2010 08:30 PM
12ax7 srpp dac output Klimon Tubes / Valves 26 30th April 2010 12:59 AM
How do I maximize piezo audiable SPL for an alarm system? Aoxomox Planars & Exotics 18 19th February 2010 10:23 AM
12AX7 gain stage output impedance Dave Z Tubes / Valves 3 3rd February 2008 05:29 PM
Page generated in 0.12311 seconds (78.74% PHP - 21.26% MySQL) with 11 queries
