| diyAudio Sponsor | ||
Hi out there,
anyone so bored that he wants to do tube-audio-noob-calculations with me? I need to make a pentode CCS with a current of 8,6mA, negative supply needed should be between 100V and 250V, tube could be EF184/6EJ7 or maybe EF94/6AU6. I have printed-out anode curve sheets scattered all around me, and don't seem to find an operating point compatible with supply voltage, needed current and acceptable linearity... I need help, or a strong drink, or both. Greetings, Andreas |
#2 |
hey-Hey!!!,
What is so complex? Consider also type 6AC7. Very high plate resistance, and can flow enough current to meet your spec. I'll take that one as an example since I have some experience using it... cheers, Douglas
the Tnuctipun will return |
#3 | |
I see that the total current with 2,2 V bias is Ia + Ig2 ( 8,6mA + 2,2mA) = 10,8 mA. So the cathode resistor would be 2,2V/10,8mA=204 ohms. |
#4 |
Hi there,
thanks for the fast response. I found curves for the 6AC7 and could follow your explanations. My problem is that for all suitable small-signal pentodes the required 8mA are either above specs (EF86) or in the very lower part of the graphs where the curves for different g1 voltages are not very equally distanced. In Morgan Jones' book it is stated that linearity is also important for current sinks. So I find it a little difficult to meet all requirements... Greetings, Andreas |
#5 | |
I looked the curves for EF184 since you said you have those tubes. When Ug2 = 160 V, and Ia = 8,6 mA, then Ug1 = -1,95 V and Ig2 = 3,6 mA. So total cathode current is 12,2 mA and required cathode resistor (1,95 V/ 12,2 mA)= 160 ohms. |
#6 | |
And yes, I totally neglected g2 current in the cathode R calculation... cheers, Douglas
#7 | |
| Operating point for 6GK5 | AKSA | Tubes / Valves | 6 | 6th October 2008 03:21 PM |
| Derive Triode Curves from Pentode Curves? | dsavitsk | Tubes / Valves | 3 | 14th May 2007 06:10 PM |
| S11E12 / 12E1: best operating point ? | Jaap | Tubes / Valves | 1 | 9th December 2006 02:29 AM |
| Best Operating point for a 2A3? | sgerus | Tubes / Valves | 10 | 2nd August 2006 12:31 AM |
| 6GM8 Operating Point | ALBQ | Tubes / Valves | 2 | 23rd November 2004 02:45 AM |
| Page generated in 0.09531 seconds (82.19% PHP - 17.81% MySQL) with 10 queries |
