used 12at7 - Page 2 - diyAudio
Old 8th January 2011, 07:21 PM   #11
SY's Avatar
Apparently Russians can't spell "bolt."
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th January 2011, 07:24 PM   #12
el156 is offline el156  Portugal
el156's Avatar
Originally Posted by DF96 View Post
One of the mysteries of the universe is why Americans measure gm in micro-mhos, but Europeans measure it in mA/V (=milli-mhos). 4400 micro-mhos = 4.4 mA/V.
Was the linear JJ 12AT7 the frame-grid version? I would expect a frame-grid to give greater linearity, if done properly, as it means the valve is basically planar as far as the electrons are concerned and this should lead to constant mu.
There is no mistery in the American measure of GM, 4400 micro-mhos is far more precise than 4,4 ma/v
Old 8th January 2011, 07:32 PM   #13
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
''B'' is pronounced as ''V'', it is the Greek 'beta' letter. Greeks we pronounce it ''vita''. Russians got alphabet from two Byzantium era Greek monks from Salonica. One's name was Cyril. Hence they use Cyrillic. The Byzantine two headed eagle facing east and west is their emblem still, Moscow was symbolically the third Rome after the fall of Constantinople and Czar meant Caesar.
Old 8th January 2011, 07:37 PM   #14
DF96 is offline DF96  England
4400 and 4.4 both contain two significant figures, so possibly same precision, except 4400 is ambiguous as it could mean four sig figs so it actually conveys less information. GM make automobiles, gm measures valves.
Old 8th January 2011, 07:39 PM   #15
SY's Avatar
4725 is four significant figures. But then again, our electricals weren't designed by Lucas.
Old 8th January 2011, 07:59 PM   #16
If I wanted to be awkward (moi?) I could say that 4725 might be about 2.5 sig figs. 4729 would definitely be 4 sig figs. Anyway, this is getting well OT so one of the mods will be slapping our wrists soon. Wait a minute: SY is a mod, so that's all right then. Have we answered the OPs question?
Old 8th January 2011, 09:36 PM   #17
trobbins's Avatar
Is there a value that relates to 100% ( NOS ) ?
- Not when just looking at one ebay item which gives one figure.
Is there a value that relates to "don't buy it " - it's only got a few months left
- Not when just looking at one ebay item which gives one figure. But there is confidence that the valve works as it is expected.
Is there a value that relates to "used" but lots of life left?
Valve testers in general do not provide comparable measurements with a high level of accuracy (as you may expect of other meters of different manufacturers). They weren't subject to an international certification scheme for accuracy, and they don't come with a golden sample that you can pass around and use as a comparison standard. As such, they tell you the valve is working based on valve tester expected range of values for a tube, and if you test many on the same tester over time then confidence builds that a particular valve is behaving in a normal manner. It gets complex when using them for more detailed assessments.
Ciao, Tim
Ecc81 12at7 316a Swap Meet 0 30th May 2008 11:51 AM
12at7 LTP CCS wicked1 Tubes / Valves 11 23rd April 2008 08:28 AM
12AT7 vs 12AU7 (interchangeable?) jn2630 Tubes / Valves 5 12th January 2008 04:34 AM
6DJ8 or 12AT7 hags Tubes / Valves 4 22nd February 2007 12:16 PM
Can I use 12AT7? Ahmad_tbp Tubes / Valves 6 25th January 2006 06:11 AM
Copyright 1999-2017 diyAudio
