How is an amp's output measured?
Old 7th January 2011, 02:01 PM   #1
Troncones is offline Troncones  United States
Troncones's Avatar
Default How is an amp's output measured?
I understand V=sqrt(W*R). Using 10W and 8ohm you get 8.9vrms.
So how do you measure the output? (I presume DIMM or O'Scope)
At what Hz?
What do you use for the 8ohm load?
If there are other questions I should have asked please feel free to fill in the blanks.
T
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 7th January 2011, 02:11 PM   #2
mastodon is offline mastodon  Netherlands
mastodon's Avatar
I'm not sure how it's done 'correctly'; perhaps there isn't a real standard. What I do myself is input 1kHz at line level and connect a an appropriate ohmic load to the output. Then measure Vpp on the output, convert that to RMS and use the number to calculate output power. When reporting figures, I will mention input signal, frequency and the value of the ohmic load.
I guess that's the best you can do, really: describe the conditions you used to measure power. All too often, power numbers are mentioned, but all the vital information is left out.
Old 7th January 2011, 02:17 PM   #3
Mickeystan is offline Mickeystan  United States
Hello Troncones
You need to first know what form the measurement instument's numbers represent. In the case of a DMM it will present the output AC voltage level in rms volts. In this case you simply measure the output voltage at the test frequency across a 8 ohm dummy load and then do the math (W = E^2/8).
On the other hand, if you measure the ouput using an oscilloscope the AC sinewave measured from the top of the positive peak to the bottom of the negative peak will be a measurement of peak to peak voltage. In this case you need to do the math by converting the voltage to rms in the eaquation. The math then is W = ((Vpp/2.828)^2)/8.
The loads are usually made up of multiple non inductive resistors paralleled up to equal 8 ohms at a high enough wattage to serve as an effective dummy load.
Amplifiers are tested for output power while being driven with sine waves and done so at multiple frequencies to understand the amplifiers ability to deliver power say at 20hz, 40hz, 80 hz, 120 hz 1,000hz and so forth up to say 20khz. This allows one to fully characterize the amplifier power delivery ability.
Mickeystan
Old 7th January 2011, 02:23 PM   #4
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
At what distortion level?
Old 7th January 2011, 02:41 PM   #5
jez is offline jez  United Kingdom
"At what distortion level? " If it's just a quick check of maximum power from an amp then it is common to measure the output at the point where clipping is just visible on an oscilloscope screen. Usually at 1KHz.
Old 7th January 2011, 02:58 PM   #6
Pano is offline Pano  United States
Pano's Avatar
That's how I do it.
Old 7th January 2011, 03:26 PM   #7
artosalo is offline artosalo  Finland
artosalo's Avatar
A dummy load can also be built by using wire wound resistors.
I for example have done one by connecting parallel 27 pcs. of 220 ohms 5 W wire wound resistors. The parallel connection makes the total inductance of such dummy load very low. Actually the small inductance it still contains makes this load to resemble a real loudspeaker better than pure resistive load.
Anyhow, the difference is minimal and this sort of load can be used for all testing purposes.
Old 7th January 2011, 04:27 PM   #8
Troncones's Avatar
Thanks everybody.
I don't have a Distortion Meter. I might play around with the RoMac sound card meter. I'm open for suggestions about an economical entry level Distortion Meter.
For now, I was just going to use a 25watt 8 ohm and watch the scope for signs of clipping. This should at least give me circuit A to circuit B comparison.
Old 7th January 2011, 04:33 PM   #9
kavermei is offline kavermei  Belgium
kavermei's Avatar
Send a message via MSN to kavermei
Originally Posted by Troncones View Post
Thanks everybody.
Try looking in the 2ndhand ads or drop by at a hamfest.
Never send a human to do a machine's job. --Agent Smith
Old 7th January 2011, 05:44 PM   #10
If using a soundcard and software to do the job watch out for input overload and destroying the soundcard!
You will need some sort of calibrated attenuator and some protection for the card. There will probably be something suitable on this very site
How is an amp's output measured?Hide this!Advertise here!
diode vca - build and measured. what amplification for output signal? Domplotz Parts 10 22nd April 2007 02:45 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
What limits an amp's output? BAM Chip Amps 9 14th July 2004 08:12 PM
How do I calculate (or measure) my amp's output impedance? Saurav Tubes / Valves 22 27th September 2003 03:55 AM
How do we calculate an amp's input and output impadance? Bricolo Pass Labs 1 13th January 2003 09:26 PM
