| diyAudio Sponsor | ||
#2 |
I don't know much about transistor circuits, but from my limited experience, there are five things that come to mind:
1. The coupling cap at the end of the tube stage (4.7uF) isn't particularly large. If connected to the next stage in the diagram, the corner frequency would be around 17Hz (not calculating the actual input impedance of the transistor itself, which would make matters worse), which is good enough, but I'm sure some people would prefer using a larger coupling cap. 2. I'm not sure about your power requirements, but it seems to me that the output stage is not necessarily the wisest solution. For one thing, it requires a fairly large 6800uF output coupling cap which, as far as I'm aware, would have to be rated for at least 115V (correct me if I'm wrong; I could very well be talking out of my behind here). Is this the best possible solution? Again, I don't know the first thing about transistor amps, but it seems that other topologies would be available that could circumvent this issue. I'm putting this remark here mostly to learn myself, not so much to provide feedback to your schematic. 3. I'm pretty sure you're going to pick up a lot of power supply hum in the tube stage with the limited filtering you're applying. It might be sufficient for the PP output stage, but I'd tap a HT line and apply extra filtering for the first amp stage to be sure. Have you simulated this power supply in any sort of software? I haven't, but it might give some useful results. 4. At first sight, the plate load of the input tube seems a bit small. I'm not familiar with this tube, but 6k8 doesn't look like much. It'll undoubtedly work, but I would like to hear the opinion of one of the more experienced gents here on this forum on this issue. I suppose there is a risk that instead of introducing a tube sound to the circuit, you might end up with some unwanted effects instead. 5. You'll have to tie the grid of the input tube to ground using a large resistor (say something in the range of 100k ~ 1Meg) in order to properly set the bias. If you don't do this, the circuit might work, but unpredictably. So again, I'm posting the above primarily to create some discussion in order to learn myself a bit too. If you did consider these issues, I'd be interested to hear your opinion on them. |
#3 |
First thing I can see wrong is over an amp of bias current in the output stage bias string, almost all of which is going through the transistor base-emitter junctions. There are no emitter ballast resistors and the current design will saturate them. (If not melt them first) Collector current would be over 2A. There is no temperature compensation either.
You need a resistor to ground on the grid of your 6n23p. I have not checked to see whether or not the plate and cathode resistor values are reasonable. The second stage is a phase splitter and the base should be biased ~0.7V above half of the supply voltage to provide symmetrical swing on the emitter and collector. You don't want any gain either and the emitter and collector resistors should be the same value. What is the rated breakdown voltage of these transistors? The power supply is also totally inadequately filtered. As designed this circuit has no possibility of working. The solid state portion even with correctly selected component values is a very bad design, and should not be built as shown. You need one high voltage supply for the tube, and a separate and much lower supply for the power amplifier stages. Approximately +/-40V rails would be appropriate for an output stage designed to drive 8 ohm loads with 60W of output.
www.kta-hifi.net Last edited by kevinkr; 7th January 2011 at 01:08 PM. |
#4 | ||||||||
![]() Quote:
It actually is 115V, should I settle with supply voltage of 100V ? How about I replace the choke, and add CRC filter in series ? Quote:
Thanks, I'll do that. |
#5 | ||||
Also, biasing is largely a matter of taste, but running this tube in this particular instance at 15mA seems to me a bit odd. I'm not saying it can't be done, but in an application like this, I would expect it to be run at between 1 and 5mA. Then again, I might be talking out of my b-cheeks. Note that it also depends on how much voltage swing you need for the next stage. This should be the primary requirement around which you design the tube stage. Generally speaking, an entry stage will be of a relatively high impedance, hence my doubts about the small plate resistor and relatively high plate current. This is intuition speaking, not so much hard maths or objective reasoning, so perhaps some of the other members could chime in and give their thoughts on this as well. Edit: actually, I am talking nonsense here. I see the tube you're using is equivalent to the ecc88, which has a low Ri. In that case, the plate load resistor is not _that_ odd, although most circuits I've come across (esp. preamp/gain stages) choose something upwards from 10k, and usually within the 30-60k range. Last edited by mastodon; 7th January 2011 at 03:49 PM. |
#6 |
maybe not where you want to go with this, but you could look at a nelson pass F4 as the SS output stage and it's own psu, then feed it with a separate tube pre-amp using your favourite tube.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#7 |
Wow. That is wrong everywhere. How powerful are you making the amp? If you use +-50v rails with 2-pairs of [good] output transistors you will get about 120-150 watts. No output cap needed for bipolar power.
A good place to start would be to get a good book on solid state amplifiers. The Doug Self and Bob Cordell books are good ones and current. Then hang around the solid state forum here, you will learn a lot. THEN... tackle the hybrid. Good luck, ..Todd |
#8 |
Tauri, give this output stage a try. You're using AC coupled output and a bunch of capacitors throught the amplifier as it is so the only difference is that this one is tested and works .. and it's dirt cheap
For desired output power adjust your supply voltage and key components (such as C2 and C3) accordongly depending your anticipated load (speaker impedance). 48V or so DC should get you into 30W into 8R output per channel power range so 60W total. Component values indicated here are for lower power. T1 & T2 can be replaced with any medium power (few hundred miliwatts of dissipation) NPN types with decent beta (100 is good, anything more is even better because R8 & R9 can be increased to lessen the AC load on tube). R11 is not just a resistor, it has 10-12 turns of roughly 1 mm diameter enamelled wire wound around it. LED1 is the cheapest (= low brightness) red color kind. Once powered up, tweak R6 until you get few tens of milivolts across R4 and R5.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#9 |
The output circuit posted by Arnulf should work well, and requires only a single supply. Mount T3 on the heatsink with the power transistors and you will have some thermal compensation as well. You need to add lots of capacitance in the low voltage supply that should be present for the output stage. CRC filtering is not a good idea with the current required for a solid state output. stage.. You should still use a high voltage supply for the tube stages, and a lower voltage supply for the output stage.
www.kta-hifi.net Last edited by kevinkr; 7th January 2011 at 06:50 PM. |
#10 |
Okay, thanks for clearing that.
| GU-50 PP amp project - Any favs? | DaveInVA | Tubes / Valves | 7 | 31st March 2010 04:03 PM |
| Help me find a Mosfet/Transistor amp project useing what I have available?? | Minion | Solid State | 11 | 9th May 2007 04:30 AM |
| Help wanted for a truly loco project. (A Tube--gainclone hybrid guitar amp!) | Spasticteapot | Tubes / Valves | 33 | 21st October 2006 08:31 AM |
| hybrid Amp project | nitelite | Solid State | 2 | 17th May 2004 05:20 PM |
| 6 channel hybrid amp project | thoriated | Solid State | 0 | 19th December 2003 11:57 PM |
| Page generated in 0.16782 seconds (86.30% PHP - 13.70% MySQL) with 11 queries |
