| diyAudio Sponsor | ||
A few days ago I bought a tubetester HITCHCOK Model I-177 plus add-MX-494 modulus.
I need to know what are the settings to test the typical European valves type ECC81, ECC82,ECC83,ECC88, KT66, KT88 EL34. Is there a list? Thank you in advance, John. |
#2 |
I don't believe the I-177 will be able to test the power tubes you listed. This file should help with the smaller tubes: http://www.jacmusic.com/Tube-testers...7/i177_108.xls
#3 |
It's possible to test these tubes....you will need to make socket adapters...
Chris |
#4 | |
Hi Bill_p I thank you for the file, I notatto that some tubes are of interest to me, and I need to know what are the settings for the 6550 or KT88 tubes and 6922 Thank you in advance, John |
#5 |
Hello
I live in Denmark, Europe, and have got a I-117b and the socket adapter kit MX-949 A/U. I need a manual, can anyone help? I would like to test my ecc88, is that a problem with this tester? Have a nice day Best regards Stefan |
#6 |
#7 |
Hi Peter, and thank you!!!!!
| help in finding tubetester meter value | anodedick | Tubes / Valves | 1 | 11th May 2004 07:37 PM |
| Page generated in 0.09028 seconds (71.62% PHP - 28.38% MySQL) with 10 queries |
