diyAudio Sponsor
Old 6th January 2011, 09:25 AM   #1
tchiwam is offline tchiwam  Finland
Default LTSpice GU19 GU29 6R3S
Hello,
I've got most of my Priboi in LTspice, at least the important part. Anyone of you have models or parameters for the GU-19, GU-29, 6R3S ?
I am also try to make the Priboi transformer in there, anyone has some good strart values ?
At the moment I am making my teeth with the 829, seems to work. I'll try to make me a spice curve tracer unless someone has one ready to suggest.
Old 6th January 2011, 01:01 PM   #2
The schematic is done, only the hard part of making the tube models is needed. It even runs, gives garbage results as the models are obviously wrong...
Later I could make the nice looking symbols for each of the tubes.
The transformer also has garbage values...
GU29 damaged piero7 Tubes / Valves 19 16th November 2011 07:30 AM
ltspice crystal jeesus Everything Else 1 18th July 2008 10:53 PM
GU29 Amp. Schematic - Audioromy or similar poynton Tubes / Valves 4 5th March 2008 07:26 AM
Using LTSpice gaetan8888 Solid State 6 19th July 2007 12:33 AM
Ltspice.... mikeks Solid State 10 13th June 2004 08:10 PM
Page generated in 0.07507 seconds (68.73% PHP - 31.27% MySQL) with 11 queries
