Dummy newb needs help with Bogen VP17X
This was originally a portable turntable with a speaker built in to the lid. The turntable, case, and speaker are long gone but I have the amplifier and it's in fairly decent working condition. I seem to have found the most info about Bogen equipment here on this forum so I figured I would see if anyone could help. I can't seem to find a schematic for this amp. I am wondering if it might be similar to one of the smaller PA amps that was adapted for hifi use. My aim is to build this into a small practice amp for guitar. How can I estimate power output in order to choose speakers for the enclosure? What changes should I make so this more suited to guitar use? I am pretty sure all of the tubes are original, should I just replace them to begin with? It uses a 6SJ7 GT and 6SC7 GT in the preamp section and two 6V6 GT's in the power amp (I think). Other tubes are 5Y3 GT and 6SL7 GT. I would also like to add a standby switch and replace the two-blade power cord with a three-prong. Is the third lead just connected to the chassis?
I know very little about tube amplifiers and even less about this specific one. Thanks for your help and patience with a total newb!
Are you a member on music-electronics-forum.com? The member who posted the VP17 schematic, baddog, has that amplifier and posted a couple of pictures in another thread. As far as I can tell, my amplifier appears to be exactly the same except mine does not have the "tape out". Another user, wrathfuldeity, had posted something about adding a presence control and other updates to a VP17. Since I am not a member, I can't search based on a user name, only keywords. If you know these two members or could get more info from them, I would appreciate it. I may have to join and try to contact them. Thank you for continuing to follow this thread and helping me out!
