AudioCap PPT Theta for tube amps? - diyAudio
Old 22nd July 2003, 03:37 AM   #1
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default AudioCap PPT Theta for tube amps?
Has anyone used AudioCap PPT Theta caps for interstage coupling between a driver and output tube? I am building an amp with 6C45pi and 300B and need to couple the two stages. Have not decided yet if I will use a CCS on the 6C45pi or an inductor.
Old 1st August 2003, 09:38 AM   #2
MIKET's Avatar
Default 6C45pi
Has anyone out there any experience with plate loading the 6C45pi with an inductor and/or CCS. Which sounded best?
I have a set of Hammond 30H 40mA chokes, both depletion mode and enhacement mode FET's coming out my ears, but not sure which way to go with these Russian beauties(6C45pi).
Old 1st August 2003, 09:57 AM   #3
Brett's Avatar
MIKET if you have the parts, why don't you try them and see what you like the best. My vote would go with the CCS, but then again, I wouldn't use a 6C45 as a driver anyway. Low loaded pentodes (as pentodes) sound much clearer to me in this application (and as GM70 and 6550 drivers)
The Rebuilding of Theta KT-88 Tube amp. Maniac Tubes / Valves 47 7th August 2015 08:36 PM
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Tube amps & MP3's jim Tubes / Valves 18 20th February 2008 04:15 AM
DIY tube amps - help?? antpink Tubes / Valves 9 3rd February 2005 05:00 AM
Copyright 1999-2017 diyAudio
