diyAudio Sponsor
Old 4th January 2011, 07:18 PM   #1
Doz is offline Doz  United Kingdom
Doz's Avatar
Default Back to back toroids
I have a passion for wiring up transformers back to back to get an HT feed, can anyone think of a reason I can't do the same with a toroidal transformer?
Little concerned about the inrush current...
Thanks in advance.
Old 4th January 2011, 07:42 PM   #2
ok, lets see, back to back transformers for an HT feed. Back to back in parallel or in series? Parallel could introduce inrush issues to the rectifier stage. Series could cuts your secondary winding current ability since the voltage on the primary probally won't be double of what a single tranny would see, unless you use 220 on the primaries.
good point is that in series, at idle, less idle current being drawn as a result of twice the impedance and inductance while maintaining 120 volts.
Old 4th January 2011, 08:14 PM   #3
Doz's Avatar
We have the luxuary of "220" volt mains here , so a 220v primary as the primary.. like this..
220VAC > 12VAC > 12VAC >220 VAC
Done it with conventional E-I transformers a million times to great effect (you can even scavenge the heaters off the "inbetween" stage)
Transformers will be identical.
Old 4th January 2011, 08:25 PM   #4
kevinkr's Avatar
You may have a bit more inrush current, easily taken care of with a inrush surge suppressor (varistor) or an appropriately rated delay blow fuse. Efficiency should be a bit better than with the typical EI transformers.
Should conducted EMI be a concern a common mode choke on the primary of the first transformer in the chain should take care of most of it. (Coiltronics and Coilcraft here in the US make suitable chokes, not sure who in the UK does.)
www.kta-hifi.net
Old 4th January 2011, 08:32 PM   #5
Doz's Avatar
Thanks kevinkr and speakerfritz.
If you ground the "centre tap" of the "inbetween" stage, it makes a common mode choke anyway ... love something for nothing
Old 4th January 2011, 10:15 PM   #6
kevinkr's Avatar
I'd have to think about that, but I don't think that is correct because the secondary windings share the same core with the primary windings and the coupling mechanism for common mode HF noise is largely electro-static in transformers so the signal will still appear as common mode and since it is capacitively coupled it will not be rejected in the receiving transformer either.
Were the above center tap comment really true you could technically make this argument with all center tapped full wave rectifier circuits from an HF EMI standpoint and from experience that is absolutely not the case.
Power toroids typically have pretty high interwinding capacitance and rather low leakage inductance which is not ideal from the standpoint of rejecting conducted EMI on the power lines.
EI transformers are somewhat effective at rejecting common mode HF EMI by virtue of their significant leakage inductance.
Obviously common mode LF is pretty effectively rejected in any transformer coupled application.
Grounding center taps in audio (not power) transformers usually results in degraded CMRR because the windings are usually not perfectly symmetrical and small differences in capacitances, dcr and electrical length all conspire to degrade balance. They are usually floating for this reason.
www.kta-hifi.net
Old 5th January 2011, 08:02 AM   #7
Doz's Avatar
Yes , I was still thinking about EI.
I have a bucket full of salvaged IEC input sockets, and everything gets one of those anyway.
Thanks for the input.
Old 5th January 2011, 11:37 AM   #8
zigzagflux's Avatar
Kevin:
Is it not true that in a traditional xfmr with electrostatic shield, that there is likely high capacitance between primary-shield and secondary-shield? Since the shield is grounded, tho, the shield acts as a guard and effectively eliminates capacitance between primary and secondary. RF or noise, once shunted to ground, becomes benign.
In the same regard, the shared #1 secondary and #2 primary take the place of the shield. Yes, there is high capacitance to #1 primary and #2 secondary, but since the middle portion is grounded, it behaves exactly like the e-shield.
At least that's the way I always figured it. IMO, best to go with a single shielded xfmr anyway.
Old 5th January 2011, 12:24 PM   #9
kevinkr's Avatar
Originally Posted by zigzagflux View Post
Kevin:
Yes, what you say is true about the electro-static shield which is why I have generally preferred transformers with them. Antek is now offering them as an option but currently don't have stock - I think this will go a long way towards answering the conducted emi issues in toroids assuming of course that the inductance in the shield and ground wire is low..
WRT to the center-tap, your comment would be most true at the low end of the EMI spectrum, the winding inductance would prevent the HF/VHF conducted EMI from actually seeing that grounded center tap. I've certainly seen plenty of conducted emi on the outer legs of center-taped secondaries. (A few uH of winding inductance for example is enough for distant lightening strike generated transients to blast right through..)
For the same reason I haven't found the back to back transformer approach to offer the kind of isolation I would like to see theoretically speaking.
When I was still in business a local transformer house built all of my power transformers to my specifications which included an electro-static shield between the primary and secondary. Sadly they sold the business and I can no longer get good transformers built locally. Some boutique vendors cannot be persuaded to place and electro-static shield between primary and secondary.
In truth I think a common filter ahead of the transformer solves most of these issues, but of course there are the endless arguments about the effect they have on the sound.. A popular tweak in many cases is to remove the filter, and in some cases I suspect the lower current rated devices have appreciable dcr which in some circumstances might be audible I suppose. I've never reliably been able to detect a difference, but have been able to convince myself on the spot that I did..
www.kta-hifi.net
Old 5th January 2011, 03:45 PM   #10
zigzagflux's Avatar
After experiencing problems with RF in my first few tries with DIY tube gear, I will only use shielded transformers from now on (IT and OPT excepted, of course).
For a good source, I think you may have recommended ElectraPrint to me a few years back; I have been very happy with the results, albeit the pricing is high. You also have to be specific about how you want the transformer to operate (loaded or unloaded voltages, etc). But in the end you get a great product.
As much as I like Lundahl's products, I have not had the best results with their power transformer. Let in a lot of noise (I have an AC drive running my well pump, and it puts out a ton of HF hash). I don't believe you can get shields with their C core products.
How to get TSP for two drivers back to back in anti-phase (dipol)? schro20 Full Range 1 6th January 2010 09:58 AM
Back to Back transformers and safety ground dsavitsk Tubes / Valves 1 9th February 2009 10:10 PM
back to back coupling capacitors reddog Solid State 5 3rd January 2006 06:59 AM
(Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions paulspencer Multi-Way 9 15th August 2004 05:34 AM
Back to Back Polarized Electro's EchoWars Solid State 11 15th November 2003 09:30 PM
Page generated in 0.12730 seconds (89.27% PHP - 10.73% MySQL) with 11 queries
