Twisted Heater Wires
Old 2nd January 2011, 08:42 PM   #1
Michael Gaines is offline Michael Gaines  United States
Default Twisted Heater Wires
I have been reading for a while and finally had a question that I could not find an answer to.
I understand how twisting wires can help reject unwanted common signals.
Wikipedia has a good short version of the benefits however they leave out a lot of the math.
I also understand that the heater voltage should be higher than the cathode so that it minimizes the influence of the plate/cathode current flow.
Is there a sound reference that explains the reason for twisting the heater wires?
I understand that high impedance, small signal parts of the circuit would benefit. Alexander Graham Bell figured this out.
I don't understand the need in a low impedance, non- amplified situation like heaters.
I connected a pair of un-twisted wires to my scope and saw a lot of rf in the +\- 5mV range. But as soon as I terminate the wires with a hundred ohm resistor the rf goes to zero. This sort of simulates the heater resistance.
Old 2nd January 2011, 09:03 PM   #2
SGregory is offline SGregory  United States
Just as twisting the wires reduces noise pick-up it also helps cancel noise emission. The heaters are not necessarily quieter, but all of the sensitive stuff (signal) around the wires don't have to listen to it.
It also pays to route the twisted heater wires away from the signal path in the corner of the chassis if possible to minimize pick-up.
Living Life Doing the Waltz in 4/4 meter.
Old 2nd January 2011, 09:24 PM   #3
imfree707 is offline imfree707  United States
imfree707's Avatar
Send a message via Yahoo to imfree707
Default It's Magnetic
The best reason to twist tube filament wiring is to reduce the emission of magnetic flux radiation type hum. The heater circuit of a few tubes in parallel can carry several amps of AC current and can radiate hum into audio grounds if filament wires aren't twisted to cancel hum flux radiation. That's my best guess.
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
Old 2nd January 2011, 09:55 PM   #4
wakibaki is offline wakibaki  United Kingdom
Banned
Yes, but the hum pickup is taking place in the valve grid circuit, which is both high impedance and amplified.
Twisted pair provides immunity from induced (differential) noise (on the pair) because the wire picking up radiation differentially (the one nearest the source in the case of untwisted lines) is constantly being switched for the one furthest away. A similar reduction in radiated interference (hum radiation) is achieved in twisted pair by cancellation of the radiated fields. This can be thought of as analogous to the reciprocity theorem in antennas without resort to a mathematical treatment.
Not my best use of English, but you probably get the idea...
w
Old 2nd January 2011, 10:47 PM   #5
trobbins is offline trobbins  Australia
trobbins's Avatar
I concur with above comments, and can elaborate that distance is your friend between EMI emitter (heater wiring carrying 50Hz current) and antenna (high impedance grid circuits being amplified), given that radiation level drops with distance (ie. keep the two sets of wiring separated by as much distance as possible).
Radiation level also drops with heater current level (ie. either use discrete heater feeds to preamp sections, or make those feeds the 'end of the daisy-chain').
There are also many subtle techniques to improve hum immunity (such as DC elevation of heater AC voltage, and wiring configuration at the valve socket, and using a socket with centre metal tube.
Ciao, Tim
Old 3rd January 2011, 12:17 AM   #6
kruesi is offline kruesi  United States
kruesi's Avatar
Two of the factors that affects a circuit's ability to radiate a magnetic field are the area enclosed by the circuit and the current through it. Heater wiring in its simplest case (the transformer with its two wires connected to a load) is essentially a single-turn coil with the heater current flowing through it. If the area of this coil is made very small by placing the conductors close to one another (most conveniently done by twisting them together) the radiated field will be minimized.
Conversely, the worst thing you can do is to wire the heaters in such a way as to run each of the conductors in opposite directions from the transformer so as to make a single loop enclosing the entire chassis.
I'm just looking at the radiated magnetic field here- none of this has anything to do with grounding, etc.
Nor does it have anything to do with the reason we use spiral heaters within the certain tubes.
Nor does it have anything to do with a balanced (differential) circuit's ability to reject a common-mode signal (such as a hum field)
This has only to do with a means to reduce the radiated magnetic field from the heater wiring -attacking the problem at its source.
Old 3rd January 2011, 03:00 AM   #7
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
Forgive my ignorance but as more of an SS guy, why would you not use a regulated DC source for the low voltage heater current with local decoupling cap at each tube? Unless of course if your goal is to have a valve only circuit might complicate it a bit.
Small diodes and regulator IC's are very cheap.
All the trouble I've ever been in started out as fun......
Old 3rd January 2011, 03:23 AM   #8
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
hiya cbs - sounds great, but often you want an elevated or floating supply - tough to do when regulating and often unnecessary if good lead dress is followed.
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 3rd January 2011, 04:22 AM   #9
trobbins's Avatar
CBS, it's a pain having to rectify and filter an AC winding to get all that heater power. Most PT's have 6V3 windings, and require schottky's to reduce losses otherwise you go under voltage on the heater. Largish electrolytics are needed to cope with the ripple current. Rectifying the heater can introduce rectifier noise. And one often gets the same hum reduction with a much simpler elevated DC applied to the heater.
Wrt kruesi's comments, the tpi and turn uniformity, and thickness of insulation of the wires used for heater cabling can be an influence, but starts to get in to the extremes.
Tim
Old 3rd January 2011, 07:23 AM   #10
rjb is offline rjb  New Zealand
Don't bother with DC on the heaters, or with shielding.
Tests I ran years ago showed twisted and properly run AC lines gave results just as good as far as hum and noise was concerned. However proper routing is critical. Don't try to put them on a PCB. Larger bases (eg Octal valves 6V6.6SN7 etc )are easier to achieve good results than those with smaller valve bases. I also prefer to use lower gain triodes in the early stages. High gain pentode pre-amps can be difficult if the layout is poor.
Twisted Heater WiresHide this!Advertise here!
twisted/isolated/shielded wires? 2bz Tubes / Valves 9 8th September 2014 11:59 AM
Heater wires through conduit mashaffer Tubes / Valves 5 7th January 2008 05:21 AM
would twisted pair from a network cable be suitable as hook-up wires inside an amp? jarthel Tubes / Valves 31 24th March 2007 10:24 PM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
Please,a) cause of high pitched hum, b)DC wires twisted or not frank2395 Tubes / Valves 3 1st May 2005 07:18 PM
