RH84 (EL84) Choke etc...
Old 4th January 2011, 02:59 AM   #31
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Originally Posted by platplaas View Post
I can't seem to find transformers with the double 6.3v.
You should be able to parallel all three signal tubes (12AT7 and two 6BQ5) off a single 6.3 volt winding. The only time you really need separate filament windings is when you are using directly heated tubes.
Old 4th January 2011, 03:23 AM   #32
platplaas is offline platplaas  Canada
Thanks. Out of curiosity - does anyone have suggestions for how to order the power transformer such that it could be useful for future projects down the road? I'm wondering whether to oversize etc?
Old 4th January 2011, 03:05 PM   #33
VictoriaGuy is offline VictoriaGuy  Canada
If you do a decent job building it, you could probably sell your RH84 (down the road). That could generate the $$ for the next bunch of parts.....
Your parts box will tend to increase in size with time as well - dumpster diving and scanning CL for old hifi gear, will build up your collection of power transformers.
So my advice would be to get what you need for the RH84 and let the next project fend for itself, for now.
John
Old 5th January 2011, 07:04 PM   #34
Trout is offline Trout  United States
Trout's Avatar
Now that I have the choke and output transformers settled....
I'm a little puzzled about the power transformer. The schematic calls for 600v (300-0-300) plus 6.3v x 2 for the filaments plus 5v for the rectifier circuit.
I can't seem to find transformers with the double 6.3v. I did find one at Edcor but it also has a 25v and goes for a fairly steep price: EDCOR Electronics Corporation. XPWR167-120
Hammond has the 372jx but the Hammond site seems to indicate that it only has a single 6.3v (vs Parts Connexion which seems to be worded such that it might be a double 6.3v)
If anyone can shed light on this it would be appreciated. I am a bit puzzled by the transformers because a lot of people talk about using old iron...but if it is so hard to find the right specs in even new iron then I'm not sure how they make old iron work?
You might look into this budget outfit for a transformer. I have used a couple of these for this exact amp and they work perfectly, Bonus, dual 6.3V taps
TUBE PWR XFMRS - Musical Power Supplies Inc.- Quality Tube Amplifier Parts You CAN Afford
Part number PT325.2
Old 7th January 2011, 04:52 AM   #35
Sometimes you have to be a bit creative with the rectifier section to get the right B+....all part of the challenge.
For small amps usually old iron will provide enough amps on the 6.3v heater winding. It helps if you know what the power transformer was driving in its 'previous life'.
John
Old 7th January 2011, 04:56 AM   #36
I've dealt with MusicalPowerSupplies in the past. It would probably be a good idea to drop him an email to confirm stock on hand. (Sometimes he has stuff that isn't listed on the website as well. He was trying out some 'HiFi' ideas 1-2yrs ago.)
John
Old 7th January 2011, 08:11 AM   #37
Doz is offline Doz  United Kingdom
Doz's Avatar
You can always place a capacitor across the choke to resonate it. This will improve the ripple on the DC.
There's some info here: Inductors and Capacitors Together
Take your AC frequency and multiple by 2 if using full wave or bridge rectification, then work out the value of C. Pick the nearest preferred value and place in in parallel with the choke (don't use an electrolytic!). I always get three caps, one nearest the calculated value and one either side, then pick the best! Most chokes lose a little inductance when passing current.
Old 28th February 2011, 04:01 AM   #38
The amp is built!
Sounds great - but I have a question. The edcor gxse transformers have a 40% tap for ultra- linear. Can I disconnect the screen resistor and use the ultra-linear tap instead? Or does the amp need more substantial modifovations?
Old 28th February 2011, 01:26 PM   #39
Ty_Bower's Avatar
Absolutely. I would suggest keeping a small resistor in series between the screen and the UL tap. Something about 100 ohms, 1/2 watt should suffice. It helps protect the screens during startup while the power supply stabilizes.
With the UL connection, you will get less power out of the amplifier.
Old 28th February 2011, 03:27 PM   #40
Great - I'm going to give ultralinear a try. What to expect for sound differences?
RH84 (EL84) Choke etc...Hide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
FS: EL84 EI Yugoslavia & EL84 Tungsram NOS Bulk radiostar Swap Meet 3 29th January 2012 08:46 AM
my third RH84 mctavish Tubes / Valves 12 11th September 2009 03:01 PM
RH84 bias change whith different el84 is use tim614 Tubes / Valves 1 26th June 2009 10:23 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
