RH84 (EL84) Choke etc...
Old 2nd January 2011, 04:05 PM   #11
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Originally Posted by platplaas View Post
If I use a 10H (vs 20H) choke - would I need to adjust the value of the 220uf Capacitor?
I wouldn't bother. 10H is a pretty good amount, and so is 220uF. You should have plenty of filtering. I've had good results using a 6H choke with 120uF filter cap after it, even into efficient (>100dB) speakers.
Old 2nd January 2011, 04:10 PM   #12
platplaas is offline platplaas  Canada
Thank you everyone!
Old 3rd January 2011, 12:16 AM   #13
Would someone be able to explain the significance of the "frequency response" data on different transformers? What does this mean in real life performance / audio? Does it affect the frequency response?
e.g. From Edcor for 5k to 8ohm output trannies:
- Bottom of the line: XSE 10-8-5K, 70hz to 18khz, $17.22
- Middle of the line: GXSE 10-8-5K, 40hz to 18khz, $26.10
- Top of the line: CXSE 25-8-5K, 20hz to 20khz, $83.50
Old 3rd January 2011, 12:25 AM   #14
6L6 is offline 6L6  United States
6L6's Avatar
This measurement is hugely important for audio.
It has to do with the frequencies that the transformers can pass.
Hi-Fi Audio frequency range is considered 20hz to 20Khz, and only the CXSE series can reproduce the entire range.
In real life the XSE will have no bass, the GXSE will have poor bass, and the CXSE will sound good, with bass as good as the circuit can pass.
In general, it's a mass thing with output transformers. Big ones are the only ones with bass.
Old 3rd January 2011, 01:29 AM   #15
VictoriaGuy is offline VictoriaGuy  Canada
Transformer 'Frequency Range' is not a sharp bandpass filter situation- the response 'drops off' at the low and high end. Without a spec like '-3dB' or similar, it is impossible to tell how quickly the frequency response is dropping, and how poorly the transformer will perform. You really need a graph to tell you what's happening. And, you need to know the power level that was used during the test. Response with 1mW will look a lot better than at 10W. (One reason you can use a small OT in a headphone amp and still get decent bass...) Your low-power RH84 will be less demanding in a somewhat similar way.
What's your budget?
For info on the CSXE, and Hammond equivalent see Output Transformers
Old 3rd January 2011, 01:31 AM   #16
Ty_Bower's Avatar
I'm not buying that story. I've used the GXSE with low plate resistance DHTs, and achieved very satisfying bass. I believe that Edcor's ratings refer to the lowest frequency that will be reproduced (within 1 dB?) at full rated power. At less than full power, my experience has been that you will get good quality low frequency reproduction - even at frequencies well below the Edcor's specifications. Even if that weren't the case, 99% of the people out there simply do not have speakers capable of extending down to the 20 Hz octave anyway.
I'm not trying to discourage anyone from buying the best transformers they can afford. I'm just saying it's ridiculous to say the XSE has "no" bass, or the GXSE has "poor" bass. I'm certain my experience is not unique, and there are many other satisfied customers out there who have had good results with the X and GX line.
Old 3rd January 2011, 01:33 AM   #17
+1
Tubelab likes the XSE (see his webpages)
Also, I built a RH84 with good bass using guitar amp-type OTs.
John
Old 3rd January 2011, 01:43 AM   #18
6L6's Avatar
I am not implying that it is a sharp bandpass. Sorry if it came out that way.
As for the other transformers having good bass, that is a distinct possibility. My question is at what power does the, for example, XSE's 70hz roll-off occur? What happens if it is only a few milliwatts? (Which I doubt) The stated bandwdith, at full power, of the CXSE will help make sure that the bass is reproduced fully, at whatever output your amp can produce.
In my experience, I have never regretted buying "too much" output transformer. I have, however, really regretted buying small ones.
Old 3rd January 2011, 02:12 AM   #19
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
For any of them they are operating at such a low % of maximum design capacity (what will the RH84 produce - 3W?) that the bandwidth rating is pretty irrelevant.
Having said that, the cost difference between the G- and the bare XSE is so small, it would be a no-brainer for me - go with the GXSE...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 3rd January 2011, 02:33 AM   #20
Thank you everyone. This is now more clear.
I'm going for the GXSE model as the RH84 puts out about 3.5w.
Would the GXSE 15w model offer any advantages over the 10w model? I'm thinking not, but if the frequency performance is based on 40hz at 15w then there is more cushion for performance at 3.5w?
RH84 (EL84) Choke etc...Hide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
FS: EL84 EI Yugoslavia & EL84 Tungsram NOS Bulk radiostar Swap Meet 3 29th January 2012 08:46 AM
my third RH84 mctavish Tubes / Valves 12 11th September 2009 03:01 PM
RH84 bias change whith different el84 is use tim614 Tubes / Valves 1 26th June 2009 10:23 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
