#11 |
Nice. His problem seems to be limited space tho...no room for an extra tube.
#12 |
Yeah that can be a problem.
But that is why I built this as a stand alone unit. I used a large chassis and will some day put it in a smaller enclosure but, I currently have two Dumble style amps, a 50w and 100w so this way I can use the loop with either one. I have a TC Electronics G Sharp effects unit that sits on top and it handles the delay and reverb duties and then I also have a pedal board with the amp foot switch for overdrive and boost, a modulation pedal, chorus, tremolo, a EHX Stereo Delay, then back to the loop. It all works very good together. Some guys like simplicity, some like to fiddle with knobs. I like to be able to dial in the tone I want without sacrifice.
Tom Keep that smoke in the amp! |
#13 |
hmm a valve effects loop separate to the amp? i like that idea, i think i might make that another project to do. thank you all very much for your help, though for this amp, i think il go with the voltage divider at the cathode follower and then a MOSFET recovery stage to the tone stack, until i have built the effects loop unit that is
#14 |
You know Metro Amps has a Mosfet FX loop that apparently works very well for SS.
A little expensive but a lot of the Marshall guys like it. Zero-Loss FX Loop Kit - $95.00 : MetroAmp, Amplifier Kits and Parts Online Store
| tone stack switchable inductor | hewo | Instruments and Amps | 2 | 29th March 2011 02:14 PM |
| Passive 2 band tone stack for guitar | SouPortugues | Instruments and Amps | 9 | 11th August 2009 03:35 PM |
| Tone Stack Challenge | cservonyec | Tubes / Valves | 13 | 3rd April 2009 01:51 PM |
| enough gain for James tone stack | PRNDL | Tubes / Valves | 17 | 21st December 2007 02:28 PM |
| Tone Stack Calculator or tsc ??????? | prorms | Solid State | 9 | 21st December 2006 03:33 PM |
