Do you select the mA based on idle current or peak?
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie. |
#2 |
what application ie power tx or output?
Meh - in either case, select with an easy 20% over-capacity, more if you can afford it. A loafing tx is a happy tx...
"Folks, you can't prove truthiness with information. You prove truthiness with more truthiness. In a process known as truthinessiness." - Stephen Colbert, The Colbert Report |
#3 |
I'd select based on the RMS current. Allow a good margin.
~Tom |
#4 |
#5 |
Banned
Based on the max power handling, input or output regardless. This will depend on the class of amplification and maybe the efficiency. Unfortunately you will have to think.
If you think in terms of the power this should keep you from going too far astray. w |
#6 |
Sorry I thought it was a simple question. Newbie mistake!
I'm working on a SE 6BQ5 amp that I hope will put out about 5 watts. The idle current, power stage plates+screens + gain stage plates is about 100mA. The peak will be about 200mA. I have two Power Transformers to choose from. 275-0-275, 150mA and 275-0-275, 200 mA. When selecting the power transformer do you use the idle load of 100mA or the peak load of 200mA? A short comment on why would be appericated.
#7 |
just go with the big one. The cost difference will be negligible and the performance difference will be appreciable
#8 | |
The 150ma tranny will be all you need. No reason for overkill unless you want to spend more, have a heavier amp and a larger chassis. Keep in mind you don't want to crowd the all trannies together. You need an adequate margin of space to eliminate magnetic coupling and hum.
#10 |
Thanks everybody for your patience and replies.
I think I got off on the wrong foot by trying to keep my original question brief so let's try this again. I'm working on a two channel SE 6BQ5 amp that I hope will put out about 5 watts. The idle current power stage plates+screens + gain stage plates is about 100mA (which most of know by heart). I'm struggling with a little confusion about current requirements. From what I have read and from studying load lines it seems clear that when you increase the grid voltage the current goes up. I assumed this increase would come from the power transformer. Then to further my confusion I read in "Valve Amplifiers" from the chapter Choosing Caps and Transformers that for class A amps "the quiescent current equals the peak current required at maximum power output". The conclusion is, I missed something along the way. To short cut my problem, for now, I ask you. I have a 150mA and a 200mA 275-0-275 transformer, which should I use? The answer would be helpful. Why would be very helpful. In addition, a tip on entry level reading about power transformers would be appreciated. The tube books I have are short on explaining Power Tx's.
| phono amp question - adding input tx | wicked1 | Tubes / Valves | 7 | 21st September 2010 06:01 PM |
| Heathkit UA-2 output tx wiring question | The Donk! | Tubes / Valves | 2 | 19th March 2008 01:20 AM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Newbie Question | andrewcubbie | Digital Source | 0 | 16th April 2005 08:00 PM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 10:49 PM |
