Parallel amp connection to speakers, SS + tube - Page 2 - diyAudio
Old 1st January 2011, 11:24 AM   #11
To the OP - If your AV processor/amp has PRE-OUTS you could hook up the tube amp to your front right and front left outputs and usually there will be an option on the HT unit to listen straight analog bypassing all the stuff inside for HT sound processing. Just an idea no one mentioned yet.
Bob
tube-like SS power amp rtill Solid State 47 13th April 2009 12:06 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
Bi-amp Between Tube, and SS alexmoose Tubes / Valves 11 19th April 2006 01:16 AM
effect on box volume of series vs parallel connection of speakers? wintermute Multi-Way 2 8th July 2005 01:14 AM
parallel connection rulezzz Chip Amps 39 22nd February 2004 01:59 AM
Copyright 1999-2017 diyAudio
