diyAudio Sponsor
Old 29th December 2010, 10:26 AM   #1
jim is offline jim  Belgium
Default Loose pin on a JJ 300B
On one of my JJ 300B's there is a loose pin. (see pics)
Any idea how to fix this?
Thanks,
Jim
Old 29th December 2010, 12:09 PM   #2
316a is offline 316a  England
316a's Avatar
Thanks,
Jim
Insert into socket and don't worry about it . Fix the issue with a new 300B once this one goes bad
316A
Old 29th December 2010, 03:03 PM   #3
kevinkr's Avatar
If you must do anything a dab of epoxy is about all you can do.. 316a has a good point as well.
www.kta-hifi.net
Old 29th December 2010, 03:32 PM   #4
Don't listen to the above posts.
First you must remove the base of the tube. Using a pair of pliers to grip the base, hold the tube tightly and rotate the base until it comes off. This may require some amount of force but don't be concerned.
Once the tube shatters into a million pieces from the unsuccessful attempt to remove the base order a new tube.
Old 29th December 2010, 03:49 PM   #5
kevinkr's Avatar
www.kta-hifi.net
Old 29th December 2010, 10:45 PM   #6
antiquekid3's Avatar
No, no...get some nichrome wire and melt the glass at the base. Then get a new base, hot glue it back together, and hope it works!
But really, some superglue right at the base of the pin should work just fine. That's how I've fixed several tube pins, at least.
Kyle
Old 30th December 2010, 06:12 AM   #7
Funny guys!
I think I'll take the 300B to sealing & epoxy specialists at work and see what they can do.
FS: JJ 300B Matched Unused eeyore Swap Meet 0 10th January 2009 11:24 PM
Sourcing JJ 300B tubes zigzagflux Tubes / Valves 3 24th May 2008 05:02 PM
Min 9-pin or 7-pin sockets to fit octal-sized holes? ray_moth Tubes / Valves 8 1st January 2008 05:15 PM
New production Tesla KT88 and 300B not JJ kgbamps Swap Meet 0 25th January 2004 04:12 AM
JJ Tesla ECC99 as a driver for 300B-2A3 konstantin Tubes / Valves 6 1st July 2003 08:43 PM
Page generated in 0.08558 seconds (74.59% PHP - 25.41% MySQL) with 11 queries
