| diyAudio Sponsor | ||
hello community
I am in the mist of building a 12ax7 preamp that i could use with my fender twin reverb. I have completed my power supply schematic and ordered all the parts. I am now building the schematic (using TINA) for the main curcuit. I am trying to keep is nice and simple. I came here looking for some feedback on the following. First- it wouldnt hurt to get some eyes on my power supply schematic. (see attached) Second- well It got too late to finish the mainbaord schematic tonight, but i hope to have that posted tomarrow. The power supply is there now. I will appreciate all feedback on the design. Thanks for your time. |
#2 |
Just a quick question,
Are the AC voltages peak or RMS? I think the DC values may be low for some of the caps! Think about off load.(warm up) How many heaters are in the circuit I guess in series? Think about start currents! The lm7812 dissipation may be an issue. The cold resistance of the heaters is very low even in series. Just for interest measure them cold DC resistance and work out the current. Work out the Vd across the regulator and wattage. Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 28th December 2010 at 11:58 AM. |
#3 |
300 V ac in -> 275 V rectified??
#5 |
Second Miniwatt's comment. How do you get those voltages?
Why not split your dropping resistor and make a CRCRC supply? It will reduce your ripple. The best way to look at both of these issues, is to download PSUD and do some sims. It's accurate and dead easy to use. SY, I wondered the same. But he does specify a series resistor in a note. Sheldon |
#6 | |
Also, depending on the preamp circuit, it may or may not be a good idea to have the heater supply referenced to ground. It would also be a good idea to set it up so that common mode noise is not inadvertently injected through the heaters.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#7 |
M greg- thanks for catching the cap v values error- that was supposed to be listed as 350v rating, not at 250v.
There will be 2 heaters in the circuit. I will have to give some thought on how to run them- I will be working on the schematic today/tomarrow. The lm7812 issue and the cold heater resistance- Ill get back to that in a few days when parts arrive- Ill give it some thought. Miniwatt- I am not sure about these values either- I have the transformer and when i tested it, it had an output of 300vac. But that was just the transformer, I havnt been able to measure these values activly. the 275vdc rectified- I had an extra bridge rectifier and wired it to the transformer and measured 275vdc from it. It is not the rectifier specified in the circuit. I understand your skeptisism of those listed values. I prob should have listed them in a note instead of lying them right in the schem. SY- I hadnt given much thought to the LEDs. as soon as i read your comments i realized there has to be a better way to incorperate them- Ill work on them. |
#8 | |
As soon as you add a filtering capacitor(s) after the rectifier the DC voltage will be some 350 to 400 volts. So you should use capacitors with 450 V rating. Forget the LED at high voltage line. Instead use some other indicator having higher voltage rating and use proper series resistance. In case of LED, some 99,5 % of the used power will dissipated in series resistor. |
#9 |
I prob should have listed them in a note instead of lying them right in the schem. Please put the values on the schematic notes are OK, however it helps so people do not over look information! I think you will find that a capacitor on your DC after the rectifier will give you a different voltage. Probably higher than you have allowed for. You may find that a soft start for the heaters will help! Lots of ways to do it , resistor with timed shorting contact, soft start regulators etc. Hi Artosalo Same thoughts bet me to it!lol Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 28th December 2010 at 04:54 PM. |
#10 | |
Sheldon |
| 12AX7 preamp on 375V | off1 | Tubes / Valves | 14 | 8th November 2010 06:39 PM |
| 12ax7 preamp. | longji98 | Tubes / Valves | 20 | 13th September 2008 05:06 AM |
| 12AX7 preamp project | Mrpong | Tubes / Valves | 0 | 24th January 2006 11:47 AM |
| 12ax7 preamp | Antonix | Tubes / Valves | 4 | 17th November 2005 02:52 PM |
| 12ax7 preamp,need help. | digi01 | Tubes / Valves | 13 | 12th April 2004 07:00 AM |
| Page generated in 0.11101 seconds (87.49% PHP - 12.51% MySQL) with 11 queries |
