Output Pentode Screen at half Plate voltage - Page 4 - diyAudio
Old 5th April 2012, 11:06 AM   #31
There are arguments about the tone of the JJs, like about everything else in music electronics. Some guys will get in an uproar that it isn't a "real 6v6." Some day I'll sit down with some and dig through the specs and maybe develop an opinion other than, "my customers like the sound and don't come back too soon."
Old 5th April 2012, 12:28 PM   #32
AJT is offline AJT  Philippines
AJT's Avatar
the jj 6v6 i've seen has plate structure not like any that ive seen in 6V6GT's of times past...
next time i meet one i'll put higher plate voltage and see what happens....
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 3rd May 2012, 12:41 AM   #33
mr2racer's Avatar
Hey All,
Doesn't it seem likely that the half voltage axiom is that using the center tap and one end tap gives you half of B+? What I wonder is in drawing from one end tap and the center tap does that unbalance the secondary?
Pentode cathode follower with regulated screen voltage? G Tubes / Valves 14 19th November 2013 12:01 AM
Do EL34s in pentode mode PP AB1 sound better with lower screen voltage? ray_moth Tubes / Valves 11 1st December 2010 03:59 PM
plate and screen voltage screenplate Tubes / Valves 9 10th May 2010 05:11 AM
Low plate voltage pentode (<40v) for diff pair? Rescue Toaster Tubes / Valves 3 2nd September 2006 01:56 AM
Setting Pentode Screen Grid Voltage dshortt9 Tubes / Valves 1 20th January 2003 12:22 AM
Copyright 1999-2017 diyAudio
