Show off your P2P wiring.
Old 27th December 2010, 06:33 AM   #1
bigjppop is offline bigjppop  United States
Default Show off your P2P wiring.
I'm trying to get myself spun up for my first P2P attempt on a tube amp and I'd love to see some shots of how others have done this. Close up shots of the business side of any of your tube projects would be greatly appreciated. I'd love to see what the newbies have done, and the experts.
Old 27th December 2010, 06:41 AM   #2
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Here are some photo's and projects that you should find of interest - hope it helps.
DIY Vacuum Tube (Valve) Amplifier Projects - Hi-Fi Audio
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 27th December 2010, 07:28 AM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
Page through the photo gallery. You'll find plenty of examples of P2P wiring. You'll find examples of how to do it properly, and how to just connect the dots and hope for the best.
Morgan Jones has a book on building valve amps. It contains many tips - including tips for P2P wiring.
~Tom
Old 27th December 2010, 07:47 AM   #4
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
glad you linked that Williamson Tom - its one of my fav's. Also, check out a Quad II for similar style of layout and dress.
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 27th December 2010, 08:51 AM   #5
darryl_h is offline darryl_h  Australia
This is a gizzards view of a 200-watt guitar amplifier I built about two years ago. A fellow member of an Australian guitar forum challenged me to recreate one of the amplifiers I used to build in the 1970's, and this was the result.
Old 27th December 2010, 09:57 AM   #6
artosalo is offline artosalo  Finland
artosalo's Avatar
Here are several hi-res photos of my point to point constructions.
http://kuva.termiitti.com/image/14866.JPG
to
http://kuva.termiitti.com/image/14878.JPG
13 pcs. all together. (just change the number xxxxx.jpg)
The main thing is that the lay-out should be done "in paper" first.
After this you can take the drill and go ahead.
Old 27th December 2010, 10:08 AM   #7
artosalo's Avatar
Here is one from the age when pcb was not even invented.
Looks nice.
http://www.technicalaudio.com/pdf/Go...-8072_xfmr.pdf
Old 27th December 2010, 10:23 AM   #8
Thanks for all the great links and photos so far; looks great! Please keep them coming!
Old 8th January 2011, 08:04 PM   #9
Fidelity Research is offline Fidelity Research  Iran
Phono preamp with passive RIAA eq.using 12AX7, 6SL7, 6SN7. (External p.supply using EZ80, C-L-C-L-C filtering, HV and heater stab. not shown)
Old 8th January 2011, 08:31 PM   #10
That's some GREAT work. You don't happen to have some more pics of the build process, do you?
Show off your P2P wiring.Hide this!Advertise here!
The beaty of p2p wiring Peter Daniel Pass Labs 77 9th January 2011 03:42 PM
Preference in internal wiring P2P and signal Henrik Juhl Chip Amps 5 22nd December 2003 08:20 PM
More beauty of p2p wiring Peter Daniel Pass Labs 35 26th July 2003 02:25 AM
Show of hands for the Montreal Sound and Image Show (Le Festival Son & Image) alvaius Everything Else 2 28th January 2003 06:48 PM
p2p wiring in Leach amp BoGoMiPz Solid State 0 10th October 2002 11:56 AM
