| diyAudio Sponsor | ||
I want to adapt these SE boards for use as a driver stage for a balanced PP power amp. XLR input for the balanced run and Probally just use an imput transformer to act a a phase inverter for non balanced runs.. I have plenty of power tubes, plenty of output transformers, plenty of power transformers. Have some good sized chasis to do mono blocks. the drive ability of this board, should easily drive 8 to 12 power tubes.
anyone done this before that can offer some insight? |
#2 |
these look like guitar amps - yes?
Too late - looked it up. Answer - yes. These are guitar amps. Are you wanting to do hi fi from these?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 | |
I have Marshall, Peavey, Carvin, guitar amps, and Dynaco, Manley, Shanling, and antique sound USA house amps. I have owned Mcintosh MC2000's, MC2105's, MC275's, Cary CAD-MB50's, etc. My experience is that a good "guitar" or band PA amp, will sound just as good as a good "house " amp. On these boards. I might change the value of C1 and C2, since I will be using 160 watt transformers that can do 20hz - 20khz. I think on this board, c1 and c2 were sized to limit bandwidth to 5 watt fly wieght transformers. What am I doing. I want to reverse engineer an amp like the the C#$@ V12 which uses SE driver boards as a driver stage. The mono version has 12 EL34's, 2 EL84's (as drivers) and at lease 2 12ax7's. So my thought is if I go balanced end to end, and rely on the XLR connection for phase inverting, I'd be half way there. For unblanced connections I could put in an input transformer to invert one leg of the signal. Last edited by speakerfritz; 29th December 2010 at 01:34 AM. |
#4 |
so you don't need huge gain then. Probably one too many gain stages in these EXCEPT if you use the EL84 in cathode follower mode.
Perhaps single-ended gain 1st stage to single-ended gain 2nd stage to EL84 CF stage to EL34s... (each phase)
| PP question - best driver stage! | andyjevans | Tubes / Valves | 23 | 1st November 2010 10:33 AM |
| Help on CCS PP differential driver stage for SE 845 amp | swordsman | Tubes / Valves | 4 | 21st April 2008 08:22 AM |
| Need a serious PP driver stage | Fuling | Tubes / Valves | 19 | 30th October 2007 08:08 PM |
| Design questions, driver stage for SE. | jane | Tubes / Valves | 11 | 3rd September 2006 09:17 PM |
| adapting unreg PSU to Brian's boards | Jimmy D. | Chip Amps | 11 | 7th January 2005 09:21 AM |
| Page generated in 0.07175 seconds (74.33% PHP - 25.67% MySQL) with 11 queries |
