How to test output transformers
Old 19th July 2003, 11:04 AM   #1
RADIOLEE is offline RADIOLEE
Default How to test output transformers
Could somebody fill me in on how to check output Xformers. I've got four old 6L6 amps I'll probably part out and eBay(unless someone here is interested) and I think one of the outputs is bad.
Thanks!
Lee
Old 19th July 2003, 11:22 AM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Before you start measuring make sure all caps are fully discharged, this may take a few minutes.
I found a good guideline on the web so there no point in anyone rewriting the book:
TESTING OPTs.
Frank
How to test output transformersHide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Matisse Fantasy waveform output test ckwong99 Tubes / Valves 35 11th January 2007 01:03 PM
FS-output transformers resident Swap Meet 0 3rd November 2004 06:51 PM
How to test output watts? Edwin Dorre Pass Labs 41 6th July 2002 02:56 PM
Copyright ©1999-2017 diyAudio
