diyAudio Sponsor
Old 21st December 2010, 04:21 PM   #1
Default 50C5s in PP ?
Has anyone tried a pair of 50C5s in push-pull? These tubes are plentiful and cheap. I figure you could run the filaments in series with a resistor, right across the 120V AC line.
Bobby Dipole
Old 21st December 2010, 05:19 PM   #2
LAJ is offline LAJ  United States
I've seen a circuit like that in the RCA receiving tube handbook some years back but never built it. With todays chip amps you can get that much power much easier than with tubes.
Old 21st December 2010, 06:26 PM   #3
Mosquito's Avatar
Hi
Somewhere in the site there is a rough sketch of a PP 50C5 self split, with CCS's under the cathodes. 5W out I believe..
I know how to walk over grapes
Old 21st December 2010, 07:35 PM   #4
mltube is offline mltube  United States
mltube's Avatar
Default This is close..
I found this on Fred Nachabaur's site under the "Little 4x4".
I hope it will help you. I have built this as a dual mono for my son and it sounds very nice indeed. It is very clean and clear and gets very loud.
Old 21st December 2010, 08:38 PM   #5
aardvarkash10's Avatar
gaaaaaah! Line supply!!!!
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 21st December 2010, 09:20 PM   #6
Mosquito's Avatar
To be used in a very dry environment and wearing rubber gloves
Old 21st December 2010, 09:28 PM   #7
mltube's Avatar
If done, totaly isolate the Line rails OFF the chassis. I'm not saying that it is safe, just what I have observed and found.
The one that I built is just as safe as any dvd player sold in stores with total power isolation. USE ISOLATION Transformer for best saftey.
Old 22nd December 2010, 08:34 PM   #8
kavermei's Avatar
Send a message via MSN to kavermei
Just to be totally clear to everyone reading this: DO NOT BUILD THE CIRCUIT IN POST #4.
Never send a human to do a machine's job. --Agent Smith
Old 22nd December 2010, 09:07 PM   #9
Miles Prower's Avatar
Haven't actually dunnit myself, but you are right: 50C5s are easy to come by. As for designs, I've done some of the preliminaries already (see attached).
The keys to sonic goodness with this particular type is to run them at Vsgsg= 90Vdc (included in the spec sheets) and not the much more common practice of running the plates and screens at the same voltage. Also, like every other pent, regulate that screen supply. Active is best, but, since this may be a project where there is a premium on "cheap", a VR90 type can be used to regulate the screens.
You can also find better PP loadlines with just a bit of spec-busting, and operating from a higher voltage DC rail. That gives the extra headroom for a somewhat shallower, and more linear loadline.
Being that the 50C5 was made for Class A, that means you can ditch a phase splitter stage. Just run the PA as its own splitter. Active tail loading of a power differential stage gives excellent balance between phases, and enforces Class A operation (not a prob here, since the 50C5s will be operating Class A anyway).
Expect just ESSSSSSSSSS-loads of hum if you do that. These high voltage heater types are more susceptable to that. Better to go with DC on the heaters. If you don't want to do that, a dirt-cheap, 12V "doorbell xfmr", run "backwards" from a 5.0V winding otherwise used to light up power diodes like 5U4s or 5Y3s will produce close to the 50V the 50C5 wants to see. It also gives you your line isolation so's you can include hum balancing at the 50C5 heaters.
The major sticking point in any 50C5 premium design is that the OPTs that were most commonly used for this type are pure: Click the image to open in full size. You will probably need to have these custom wound (Edcor and Electra Print can both do that.)
Yeah, don't. 35C5s are not the same as 50C5s, and are a good deal inferior, both from a linearity PoV, and they don't have the Pd rating that the 50C5 has. It's a question of when, not if, that thing poofs a computer sound card, a CD/DVD player, etc. May be you'll even be around to tell us about it.
(If you need 50C5s with other heater ratings, your choices are:
25C5, 17C5, 12C5 -- there is no 35V version of this type.
The 6.3V heater version is the 6CU5.)
That design just plain SUX. Its phase splitter is as inferior as you could find, has no provisions for balancing that thing, will not exhibit AC harmonic distortion balance, is not even amplitude balanced between phases. It also probably doesn't have enough open loop gain to support the required gNFB. Back in 1959 it probably sounded OK, with the cheap tuners, and turn tables that it was intended for. Of course, that's no endorsement.
These days, a solid state amp will probably sound better.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd December 2010, 12:10 AM   #10
In fairness to Fred the article from which that schematic comes does say to use an isolation transformer.
mike - www.keepingsundayspecial.org
EL84 PP output transformer for 6L6 PP class A engels Tubes / Valves 8 30th May 2007 09:45 AM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
Just another PP... jane Tubes / Valves 24 17th May 2006 04:47 PM
Page generated in 0.11990 seconds (79.00% PHP - 21.00% MySQL) with 11 queries
