diyAudio Sponsor
Old 20th December 2010, 02:20 PM   #1
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
Default Ultralinear but no UL taps.
I don't understand how this works. Maybe somebody can explain it to me.
Old 20th December 2010, 02:36 PM   #2
SY's Avatar
The screens are driven by the two 12AU7 cathode follower sections. The input to the cathode follower sections is a tapped down version of the primary voltage, adjustable by the pots. If the 12AU7 plate voltage is high enough, it could work.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 20th December 2010, 02:44 PM   #3
Cassiel's Avatar
Thanks, I might experiment with this one. Just out of curiosity.
Old 20th December 2010, 02:49 PM   #4
Yvesm is offline Yvesm  France
Yvesm's Avatar
Yeap, the 12AU7 plate voltage should be much higher than stated !
But you loose the contribution of screen current to output power.
Old 20th December 2010, 03:08 PM   #5
The ends of T1 will swing above B+, the triode cannot follow.
It provides for adjustable UL or Triode feedback, but less than
half wave. The results might not behave exactly as intended.
Such feedback will fight the pentode from entering saturation,
but would do nothing to fight the pentode from entering cutoff.
It might be some bizarre sort of Class AB crossing scheme?
Might have been better if a Triode strap resistor fed screen
directly from plate, and 12AU7 shunted excess current away?
No, even that doesn't work full cycle. What was I thinking?
Old 20th December 2010, 05:05 PM   #6
DF96 is offline DF96  England
I think the quick answer is that it doesn't work. It might work if the triode anode had a much higher voltage, about twice the supply voltage.
Old 20th December 2010, 05:45 PM   #7
Yvesm's Avatar
Glad you agree
Old 20th December 2010, 05:55 PM   #8
Bootstrapping the plates of the screen driver to the respective output tube plates might work, but now we're actually consuming power out of the primary, rather than aiding it. A neat thought, but hardly practical as shown. OTOH, I think ARC in fact did something along these lines (UL w/o UL taps), using Mosfets as screen drivers.
Dave
Old 21st December 2010, 02:07 AM   #9
tubelab.com's Avatar
There was some talk and even a few experiments along these lines in this thread. I breadboarded my circuit, but it still sits on a shelf awaiting further attention.
Adjustable distributed load discussion
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 21st December 2010, 12:53 PM   #10
teemuk is offline teemuk  Finland
half wave.
It is true that the screen voltage won't track the output signal for a full wave but in class-AB the output tube will not conduct current at those times so I don't see how this would really hinder the operation. In fact, doesn't the screen stop drawing any current even in a "real" ultralinear circuit even though the voltage at the screen does swing a full cycle? Essentially, I see the triode being capable of buffering the screen current at the times when it is actually needed to do so. ...In class-AB circuit that is; with class-A bias the incapability to swing a full wave might prove to be a problem.
Dynaco 440 Transformer Cathode/Screen Taps 6P1P 6AQ5 UL transformer TheGimp Tubes / Valves 14 30th October 2011 12:20 AM
schematic request for transformer with 4k primary and UL taps junklocator Tubes / Valves 7 26th April 2010 05:12 PM
Using different transformer taps for each needed B+ boywonder Tubes / Valves 3 10th March 2010 09:59 PM
Transcendar SE 5K 8 ohm 10 watt Output Transformers with UL taps nikolas812 Swap Meet 9 5th June 2009 10:51 PM
Output tube for 600V B+, 5800 ohm primary PP, tertiary 25% UL taps? GordonW Tubes / Valves 7 8th August 2008 10:11 PM
Page generated in 0.08699 seconds (85.43% PHP - 14.57% MySQL) with 11 queries
