Old 21st December 2010, 10:51 AM   #11
Banned
Originally Posted by merlin el mago View Post
If you change R19 for 1Meg, don't put the feedback cap C8 & change R8 to 1Meg the same value as R1 1Meg you get a symmetric balanced circuit.
Surely R19 = R2 = 100R
R8 = R1 = 1M0
C1 and C9 are recommended to be increased from 0.22uF to 1uF if the output impedance is < 100K.
This pre. operates without feedback so is open-loop gain. Are we missing a trick by the designer ?
Old 21st December 2010, 11:21 AM   #12
merlin el mago's Avatar
R8 = R1 = 1M0
Why not ask directly to Erno Borbely borbelyaudio@t-online.de?
Old 22nd December 2010, 07:57 AM   #13
Banned
As this is a cloned design, I'm sure he wouldn't be too impressed.
I'll ask him though as if I've just found the article in GLASS AUDIO.
Does anyone have GLASS AUDIO 1/97 to see if there were any addendums to the article on the Borbely or any subsequent editions.
Old 23rd December 2010, 09:42 AM   #14
Banned
Well Erno Borbely Replied.
We virtually knew the solution to the problem. But here is his answer.
Hi Andy, a 16 year old design, I am astonished, 
Anyway, I am not sure what you want to do with it.
You are saying that with INP1 grounded the amp is useless. INP1 is the input
with unbalanced source, so why should you ground it? INP2 should be grounded,
with unbalanced source, which is what the low impedance is for.
Of course if you want to use it with balanced source, then R8 should be changed to 1MEG,
like R1.
Does this answer your q.?
Wish you a very nice Holiday Season!
Erno.
Old 23rd December 2010, 02:27 PM   #15
Erno is very kind, I own a lot of his stuff.
Cheers
Felipe
Old 12th May 2011, 08:04 PM   #16
Banned
The Pumpkin/Shuntkys are almost finished now. Still not overly impressed with the colouration that the Borbellys intoduced into the equation. Watch this space and I will compare the two.
They are both EXCELLENT pre-amplifiers but I am using them with some serious High-End Hi-Fi that is showing their weaknesses.
The loser will be up for grabs.
Old 19th May 2011, 03:31 PM   #17
Banned
Although I'm a very experienced Electronics Engineer I'm new to tubes.
Having built the Borbely EB-894/211 I have a problem with using it.
Zen Mod suggested converting the circuit to SuperSymettrical which I have done. Am I right in thinking that the Borbely diagram is labelled incorrectly with +/- inputs being crossed over. It looks as though the + input derives the - ouput ???
If I connect the feedback resistor according to the labelling on the PCB I get nothing. Just a very low level signal with significant HUM. I had to go to work before I had a chance to experiment....
Old 23rd May 2011, 09:21 AM   #18
Banned
IDIOT ------ IDIOT
After checking the orientation of the cores of the XLR connectors, I found that they were incorrectly wired.
Problem has now gone away. I have decided to leave the Borbelly with NO NEGATIVE FEEDBACK and an open loop gain of 22dB.
Old 23rd May 2011, 12:42 PM   #19
Tony is offline Tony  Philippines
Tony's Avatar
hi,
i find SY's Impasse preamp tops in simpliciity and performance....i am building one although i'll use 6CG7 instead of the 6SN7.....
Super Simple Valve Pre-amp Suggestions? SimonomiS Tubes / Valves 4 29th August 2009 03:04 PM
Suggestions for a good tube line amp rotation Tubes / Valves 3 7th June 2008 10:11 PM
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Tubes / Valves 11 6th September 2005 09:52 PM
Looking for line array suggestions Danse Multi-Way 19 21st July 2005 03:38 PM
Line array wiring suggestions mazeroth Multi-Way 3 12th April 2005 11:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
