Help! Want to Diy Tube Amp!
Old 18th December 2010, 03:06 PM   #1
jtjy is offline jtjy  Singapore
Default Help! Want to Diy Tube Amp!
Hi guys, have diyed some class d amp before and wishes to diy some tube amp but do not know where to start? any recommendations for a decent tube amp kit for a beginner ?
Old 18th December 2010, 03:09 PM   #2
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Here's a great place to start! Triode Electronics Tube Amp Kits Transformers Tubes Dynaco Upgrades and Parts
Old 18th December 2010, 04:48 PM   #3
indianajo is offline indianajo  United States
indianajo's Avatar
I've bought from Triode. If they ship the wrong part, the replacement shipping is free. They also have the most convenient on-line tube datasheets. They are near chicago. Nice to see source of Dynaco replacement parts that aren't from the reject pile of the Dynaco bankruptcy.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 18th December 2010, 04:59 PM   #4
brucetassin is offline brucetassin  United States
Hi JTJY,
here is a great place to start....
boozhoundlabs.com/howto/
He goes into great detail on DIYing
a 6V6 SE.
I built one and it sounds really good.
Not golden ear tho, and I have no clue
how much power it puts out but it more
than fills a 12 X 15 room using 12" 3 way
speakers.
Old 18th December 2010, 05:02 PM   #5
mr2racer's Avatar
Is that chassis non-stick?
Old 18th December 2010, 06:00 PM   #6
Hi m2racer,
yes it sure is non stick. You may be surprised to learn the benefits of using
non-stick cake pans for chassis. the surface is so slick the eddie currents and grould-loop electrons cant stick and fall off thereby affording much better sound acoustics. the one small problem is you need to vacuum under the amp at least once a month to get rid of the stray electrons. the sound quality so so improved you can hear it all the way to the bank.
Old 18th December 2010, 06:06 PM   #7
mr2racer's Avatar
Tres cool!
Old 18th December 2010, 06:19 PM   #8
thanks guys! triode amp to me are expensive and i cant afford them as i am just a student atm. any more cheap n decent recommendations ?
Old 18th December 2010, 06:22 PM   #9
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
I found an old console at a thrift shop. I pulled the amp and recapped it and am very happy with it. It can be modded as much as I'd like, but I like the way it sounds and works with the recap. Here are some before and after pics. The nice thing about doing it this way is that you can do a little at a time and spread out the expense. My next upgrade for it will be new output transformers.
So for I have about $100 into it. The new iron will be about another $125. If I upgraded to volume pot, that might add $25 to $50. New tubes could be anywhere from $75 and up. There are a lot of helpful members on this forum, whichever way you go.
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 18th December 2010, 06:47 PM   #10
mr2racer's Avatar
There you go! A friend gave me an old Magnavox console built in 1948. I pulled the amp out, amp 101 B, and discarded the rest. For yucks I put just the 5Y3 rectifier tubes back in a few minutes ago. I have 520 V DC output. After the first cap 1.26 VAC ripple and after the second 0.00! On 60 year old caps. (I know powering up those caps without a Variac was stupid.) What is really cool is I found a second amp on eBay for $22.50. I also found a used Hammond 1650n OPT for $39.00 and a new one for $79.00. I now have most of the makings for a pair of Dynaco Mark IV clones
Search eBay with the parameter 'tube amp for repair' or 'tube amp for parts' and be patient you'll never know what you'll find.
And mikje, I have a pair of Sherwood S8000 receiver OPTs that are looking for a home.
Help! Want to Diy Tube Amp!Hide this!Advertise here!
My first and last DIY tube amp ! HFGuy Tubes / Valves 23 17th December 2010 05:16 AM
diy guitar tube amp help. Newpaltzwonder Instruments and Amps 22 22nd July 2005 05:40 PM
Chinese Tube Amp & DIY .. Pro & Con zxx123 Tubes / Valves 6 18th January 2005 09:54 AM
diy tube amp turbo_h4 Tubes / Valves 10 4th July 2004 12:47 PM
what tube preamp DIY kit to match B&W P-5 speakers skydog Tubes / Valves 4 22nd January 2004 09:48 PM
