| diyAudio Sponsor | ||
Hi guys - before I let the smoke out testing it, comments.
Note - no, its not a depletion mode device or any other format, I'm running with what I have here, so looking for confirmation that I'm in the ballpark with my figures (my first time specifying this schematic). I figure its around a megaohm of impedance anyway which is plenty for my purpose. LED string should be passing around 3.5ma, ccs is set to 1.65ma or around that...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#2 |
looks good to go
#3 |
thanks semper - all things being equal, around 2Vdc. Its the common cathode of a 1st stage ltp.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 Last edited by aardvarkash10; 17th December 2010 at 07:54 AM. |
#4 |
Interesting, the CCS will have very limited headroom, but it may not need any more than 2V?
#5 |
yeah, wondered about that - should I put a negative rail in to give it a longer tail?
#6 |
see the baby huey design and copy the ccs in the ltp
#7 |
aaaah true, but that's cheating - I don't learn as much...
OK, I cheated - negative rail advisable.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 Last edited by aardvarkash10; 17th December 2010 at 08:20 AM. |
#8 |
absolutely, you will have some voltage swing at the node where the cathodes meet the CCS.
#9 |
version 2.
The negative rail voltage is not a given - I have a bias supply I can draw from with up to -50v the practical limit. I can't get my head around the biasing (I'm looking for -1.5v relative to the grid which results in 0.825ma idle per device) - does the ccs automatically bias the devices, or, with the lowered negative rail, do I have to bias the cathode relative to signal ground using the variable resistor shown in the new diagram?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 Last edited by aardvarkash10; 17th December 2010 at 08:16 PM. |
#10 | |
Simpler to dispense with the variable resistor and connect your grid leak resistors to ground. Sheldon |
| implement CCS on a BJT darlington buffer | gianmaria | Solid State | 36 | 29th September 2011 11:19 AM |
| Advantage of a FET-BJT CCS vs BJT only | Bitrex | Tubes / Valves | 2 | 10th June 2009 03:01 AM |
| 6SN7 Cascoded CCS | korneluk | Tubes / Valves | 3 | 25th November 2007 10:02 AM |
| BJT cascoded with a Jfet: how can I make it work? | Bricolo | Parts | 16 | 7th November 2004 06:29 PM |
| FET vs BJT CCS | polsol | Solid State | 6 | 26th August 2004 11:26 AM |
| Page generated in 0.09056 seconds (77.56% PHP - 22.44% MySQL) with 11 queries |
