| diyAudio Sponsor | ||
Hello everyone,
If designing an input for an iPod/BlackBerry/MP3 player, should I use an "R" or a "C" and what value would you think? Everything that I have found online states these players use 32 ohm headsets, thus the 33 ohm resistor, and that the max power out is 30mW. Doing the math, that's around a volt. Thanks, Ray |
#2 | |
Take a look here: ipod nano dock Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 16th December 2010 at 06:09 PM. |
#3 |
My thought was to have a 3.5mm jack so that I could use a 3.5mm to 3.5mm cable. I thought that would be more "universal" whether I use an iPod/MP3 player or a BlackBerry.
#4 | |
You could just use a lead with 3.5mm plug to 2 phono plugs and connect them to any input!<<< I now know this is better because there is no chance of shorting the Ipod H/P out when you connect to the socket, however this is short protected! Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 16th December 2010 at 07:26 PM. |
#5 |
I assume the "units" would like to see a load for proper audio response. That's why I thought of the 33 ohm resistor.
#6 |
For maximum voltage transfer you want a load impedance significantly higher than the source's output impedance. Equal impedance is for maximum power transfer which is not your concern in this case.
mike - www.keepingsundayspecial.org |
#7 | |
A normal system with a mixer and amplifier has a mixer output impedance of a few ohms while the amplifier will typically have an input impedance of 47K.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| converting WAV to MP3 files for iPod? | Godzilla | Digital Source | 9 | 23rd May 2008 06:40 PM |
| line input to pioneer deck (for ipod) | troublecomes | Car Audio | 14 | 3rd November 2006 01:08 AM |
| car amplifier for low level input (mp3/ipod) | barroca | Chip Amps | 0 | 15th March 2006 04:50 PM |
| MP3 Auxiliary input | shanahan | Car Audio | 3 | 22nd September 2005 09:14 PM |
| Page generated in 0.09408 seconds (75.04% PHP - 24.96% MySQL) with 11 queries |
