| diyAudio Sponsor | ||
Hi everyone,
Iīve been thinking of cnc routing chassis from aluminium plates for a while and finally got down to making two prototypes.Ones is 3mm aluminium and the other one is milled out of dibond (two thin sheets of aluminium with a compostite core).Routed lines are just for fun or aesthetics,the holes are for volume input output connection to power supply etc. I could produce these or a "standard" model according to what most people want for a very reasonable price,sizes can be modified easily.I know this should be in the vendors forum but I am still not selling anything,just wondering if people would be interested (and like me donīt enjoy so much the chassis part of the amp...). Criticism and opinions are welcome,the ones in the picture are 200 x 140mm (sorry about the metric dimensions).Shipping wouldīnt be an issue seeing it ships in a flat envelope. Thanks for your help. GJA Last edited by gja; 15th December 2010 at 10:21 PM. |
#2 |
piker - the real has deal machined grooves for pressed in solid teflon insulation for the solid silver "wire"
#3 |
Hey, those look nice. I like the lines, although in my (wood heat) house they would be filled with dust...
BTW: never apologize for using metric. Only apologize for using stupid old SAE |
#4 |
never though about the dust...
jcx,I īm not sure I understand your post,missing something there. Anyone know what is the most used octal socket? |
#5 | |
#6 |
very nice....any custom work?
#7 |
#8 |
SAE? I think you mean "Imperial" measurements.
I agree, the metric system is easy and efficient, but it is still fun to see young kids in today's generation do fractions. Half of them scratch their head.
D-500, 700 II, 700B, (5) 400, (3) 400 II, (2) C-500, 4000 Preamp, Audio Precision System One (Dual Domain) |
#9 |
Yes 200x140 is pretty small.The idea is to find a "standard" dimension.I would just provide the top plate for the moment.Might improve the design so that you can ship it flat and fold down the sides,could be an option.
Still need to which are the most used octal sockets and noval sockets...Anyone got a clue? Last edited by gja; 17th December 2010 at 06:47 AM. |
#10 |
I was using, with good result, a 25mm DeWalt tubular drill to mount chinese ceramic octal sockets (top mount) For underside mounting will probably need 27mm or so.
For a small SE amp, a 200 X 300 mm plate will be around Ok Ask the customer to send a CAD draft with detailed lay out & dimension data, in order to avoid any misunderstanding & sent back items. Cheers J
I know how to walk over grapes |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| FS: CNC-machined aluminium waveguides | David Gatti | Swap Meet | 0 | 29th June 2009 02:32 AM |
| CNC machined aluminium waveguides for sale | David Gatti | Swap Meet | 2 | 27th January 2009 02:07 AM |
| Aluminium vs steel chassis | Rob11966 | Tubes / Valves | 86 | 22nd January 2009 04:45 PM |
| Aluminium chassis finishing | FrankDIY | Everything Else | 0 | 21st August 2002 11:35 AM |
| Page generated in 0.10471 seconds (79.36% PHP - 20.64% MySQL) with 11 queries |
