diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   300B SET amp input sensitivity, Help. (http://www.diyaudio.com/forums/tubes-valves/179202-300b-set-amp-input-sensitivity-help.html)
HP8903B 15th December 2010 06:45 PM
rongon 15th December 2010 06:55 PM
I think in order to answer that question in a meaningful way, the folks here will need to see a schematic.
el156 15th December 2010 07:01 PM
Originally Posted by manp111 (http://www.diyaudio.com/forums/tubes-valves/179202-300b-set-amp-input-sensitivity-help-post2399633.html#post2399633)
I have a 300B SET amp with 150mv input sensitivity and 100k ohm impedance. It has two 100k ohm volume pots.
I need to reduce the input sensitivity of this 300B amp to about 1V. I want to remove the volume pot.
Could someone tell me how I can reduce the input sensitivity to about 1V without the volume pot?
Perhaps I can put a resistor in place of the volume pot?
If so, how can I figure what value resistor I need?
Make a voltage divider with 15K resistor to ground and 100K resistor to the input?
HP8903B 15th December 2010 08:19 PM
That might work.
How do you know to put 100K ohm resistor to the positive side of the input? Also, why do I need a resistor on the negative side of the input?
Really, I just want to turn down the volume of the amp about 20dB.
el156 15th December 2010 08:24 PM
Originally Posted by manp111 (http://www.diyaudio.com/forums/tubes-valves/179202-300b-set-amp-input-sensitivity-help-post2399806.html#post2399806)
That might work.
What you need is a voltage divider to lower the input sensitivity,and the 100K with 15K makes it . Can you post a schematic?
Silvino
HP8903B 15th December 2010 08:44 PM
1 Attachment(s)
Here is the schematic.
So the "voltage divider" IS the two resistors?
HP8903B 15th December 2010 08:46 PM
What wattage of the 100k and 15k ohm resistors do I need?
Also, is there a high quality resistor brand that you recommend?
el156 15th December 2010 08:51 PM
Originally Posted by manp111 (http://www.diyaudio.com/forums/tubes-valves/179202-300b-set-amp-input-sensitivity-help-post2399846.html#post2399846)
Yes,I would do that! 15K from grid to ground,and 100K from grid to input.
and take the POT away.
HP8903B 15th December 2010 08:54 PM
You are talking about the grid of the input tubes?
tomchr 15th December 2010 09:11 PM
He's talking about replacing the pot (variable voltage divider) with a fixed voltage divider. From the grid of the input tube insert 15 kOhm to ground. Connect 100 kOhm from the grid of the input tube to the input connector. Remove the pot.
Regular 1/8 or 1/4 W metal film types will work fine.
A better way to approach this would be to redesign the front end to give less gain, but that's a bit beyond the project scope at this point.
~Tom
Resources saved on this page: MySQL 18.75%
