300B SET amp input sensitivity, Help. - Page 2 - diyAudio
Old 15th December 2010, 08:16 PM   #11
el156 is offline el156  Portugal
el156's Avatar
Originally Posted by manp111 View Post
You are talking about the grid of the input tubes?
Yes ,the grid of the input tubes !
Old 15th December 2010, 08:26 PM   #12
Thanks Tom for the clarification.
I found a better solution: instead of lowering the input sensitivity of the 300B amp I think I can increase the input sensitivity of my 845 amp.
I found a resistor from the input tube grid to the positive input and a resistor from grid to ground in the 845 amp. It seems like I could remove these two resistors to increase the input sensitivity. What do you guys think of this? This would be a much easier solution.
Old 15th December 2010, 08:29 PM   #13
The 845 amp also has two volume pot.
Old 15th December 2010, 08:41 PM   #14
Thank you very much for the information. This forum and its members are wonderful.
Old 15th December 2010, 08:44 PM   #15
Can I just remove the resistor from grid to ground? Or do I need a lower value resistor?
Old 15th December 2010, 09:08 PM   #16
tomchr is offline tomchr  Canada
tomchr's Avatar
Schematic?
On most tube amps you'll find a resistor in the range of 470 kOhm to a few MOhm connected from the grid of each tube to ground. That resistor is needed for bias stability and does not appreciably affect the overall gain of the amp. Leave it!
Sometimes you'll also see a resistor of a few kOhm in series with the grid. Those are called grid stoppers and are used to avoid oscillations in the tube. They are needed.
~Tom
Old 15th December 2010, 09:10 PM   #17
Got it. Thank you.
Old 15th December 2010, 09:20 PM   #18
I don't have a schematic for this amp.
Yaqin MS-300B SET amp Rodango Tubes / Valves 18 26th November 2010 08:09 AM
300B Set amp some variations MartinV56 Tubes / Valves 0 12th February 2008 09:22 PM
Input sensitivity on amp? suspencefull Solid State 25 3rd September 2006 07:44 PM
pentode driven 300b set amp - any info? trioderob Tubes / Valves 5 17th February 2006 01:52 AM
Leach amp input sensitivity Has Solid State 6 4th November 2003 08:14 AM
Copyright 1999-2017 diyAudio
