diyAudio Sponsor
Old 13th December 2010, 02:49 PM   #1
Troncones's Avatar
Default 6BQ5 Sweet Spot?-Charts for other than 250 Screen Volts?
I'm working on designing a SE 6BQ5 amp. I have built several from old Magnavox amps (see attached) but when compared to commercially available SE 6BQ5 Amps there output is a little weak.
Do you know where I can find charts on this tube with different screen voltages?
I have looked at a lot of different schematics. Most set the screen voltage at other than 250 Volts.
Perhaps a simpler question is what would be the (Sweet Spot) optimum Plate, Screen and Grid Voltages?
I'm using 5k-8 outputs (Edcor GXSE10-8-5K). I can go up to about 300V on the plate. I want to stay around 10 watts at the plate. The rating on my power Tx is 100ma. The other tubes I plan to use are a 6CA4 and a 6CG7
Thanks for any input
Tom
Old 13th December 2010, 03:00 PM   #2
Palustris's Avatar
Default tube manuals
There is plenty of great information on operating points in the data sheets from the tube manufacturers. Read the appropriate pages from the tube manuals here:
electron Tube Data sheets - E
Old 13th December 2010, 05:57 PM   #3
Troncones's Avatar
Thanks Palustris,
Some of those data sheets have more info on them than the ones I have. The Mullard one is very useful.
Old 3rd February 2011, 02:06 PM   #4
Could be your output transformers are a bit on the small side, so could be good for one or two watts.
F4 sweet spot... Skorpio Pass Labs 3 17th June 2010 08:31 PM
The Sweet Spot Nelson Pass Pass Labs 54 12th November 2009 01:53 PM
Better than the current sweet spot of value?? rick57 Full Range 4 16th June 2005 07:23 PM
ESL imaging, soundstage, sweet spot ??? michaelpage26 Planars & Exotics 6 6th December 2004 08:42 PM
Aleph Temperature Sweet Spot macka Pass Labs 12 21st March 2002 10:39 AM
Page generated in 0.07188 seconds (70.74% PHP - 29.26% MySQL) with 11 queries
