| diyAudio Sponsor | ||
My second re-cap job
I just finshed re-capping my Grundig 3028 and now I have no volume control, just one steady volume, tone is flat also Does anyone have pictures of the under chassis with nice close ups of the capacitors so I could compare? That would help alot I am a novice and not too good at using the schematic to trace the signal path I did put an ohm meter on the volume pot and it does show change so I am pretty sure the pot is fine This radio played ok except for a hum I replaced 15+ capacitors, everything I could think of or was suspect The pictures I took of the original caps were blurry and I have no nice reference (BIG MISTAKE) Maybe some idea of where to start Last edited by Omegaman; 11th December 2010 at 08:11 PM. Reason: spelling |
#2 |
Check that you haven't broken the 'earthy' end connnection of R31 (390 Ohm), or the other end of R31 which is tied to the low-volume end of the volume control pot.
Steerpike's Toybox |
#3 |
I checked R31 and the low-vol end of the vol pot is connected to R31 and the other end of R31 is connected to GND
From the GND side of R31 to the low-vol pot, I measure 386.5 ohms which is R31 |
#4 |
Well you do have a schematic - which is more than many fixers of vintage stuff have, so it isn't going to be too difficult to trace out the audio pre-amp section. It's not very big.
Is the fixed volume low, medium or loud? And is the tone normal, or poor bass, poor treble?
#5 |
Steerpike, thank you for assisting me in this problem.
It turns out I had incorrectly connected C47. (see photos) Once I matched the schematic with "as built" then the volume was restored This was a great lesson in tracing circuitry using the schematic. LESSON: ALWAYS TAKE LOTS OF PICTURES AND CLOSE UPS The tone controls do function but there is a tinny sound to the signal. I will continue reviewing the changes I made Its all good Last edited by Omegaman; 12th December 2010 at 06:14 PM. Reason: adding detail |
#6 |
I found and fixed the tinney tone problem and now the Grundig 3028 is restored to its full glorious Hi-Fi sound
Yes, I connected a capacitor wrong The .15uf 125v capacitor C58 was not connected to the output from the second coil in the circuit no harm done Excellent opportunity for me to follow schematics and trace circuits LESSON: PICTURES< PICTURES< PICTURES I also added small connectors to the speaker outputs in order to pull the chassis faster without soldering/desoldering each time I had the chassis out Now a new 3 prong power cord The radio is now worth the expense of purchasing a new EM34, or perhaps one of the alternate tubes Now its back to my 59' Blaupunkt to solve that balance control issue, then rebuild the Fisher FM-100 and recap the X-100, then I can start the recap of my VOM 869 Amp, preamp, tuner and R2R tape deck. followed by the VOM 1428 amp and 1416 tuner. Then the twin heathkit EA-3 amps and then start on the Wharfedale W70-E's and recone the Bose 301's and I'm done Thanks DIYAUDIO
Just waiing for my real life to begin |
#7 |
Those German sets are magnificent. Yours must be an export set since the German market ones only went to 100MC/s on FM.
EM34s can be disgustingly expensive, but they do look so good when you have a bright new one in!
#8 |
Since this Grundig 3028 restore is function first, I decided to forego the $50-$100 EM34 and instead go with an alternative solution
I got a 6E5C and did the simple wire mods to use the 6E5C instead of the expensive EM34. The eye works great. I placed a notice on the chassis indicating the 6E5C mods for the future generations a-coming The NOS 6E5C cost $20 with instructions
| Grundig SV 80M | vulejov | Solid State | 0 | 10th November 2010 07:10 PM |
| Recognize this Grundig oval? | poptart | Full Range | 5 | 4th December 2009 11:59 AM |
| grundig tk46 troubleshoot | thetinker | Analogue Source | 3 | 28th April 2009 01:54 AM |
| Old Grundig Fullrange fun | Pano | Full Range | 13 | 20th January 2009 11:16 PM |
| Grundig CD303, anyone know it? | tubenut | Digital Source | 0 | 30th May 2008 06:33 PM |
| Page generated in 0.09925 seconds (77.64% PHP - 22.36% MySQL) with 11 queries |
