| diyAudio Sponsor | ||
Does anybody know if it is possible to source heatsinks for tubes?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#2 |
I remember someone putting tubes under water (obviously with the leads outside) to cool them down.
#3 |
RIP
#4 |
Tubie Noobie
second the pearls
Living Life Doing the Waltz in 4/4 meter. |
#5 |
maybe you don't need to heatsink the tube - they cool by radiation because the plate in in a vacuum so you just need to surround the tubes with cool surfaces to absorb the radiated heat ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#6 |
Heatsinks on tubes may actually make them run hotter, since they intercept the normally radiated radiant heat and have poor thermal contact with the glass. Probably were used to keep the surrounding components from getting hot by converting all the radiant heat to vertical convected hot air instead. A fan could help, but that would likely work even better without the heatsink in the way.
Ohms Law V = I R |
#7 |
hell, how do you see the glow if its wrapped in a heatsink???
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#8 | |
#9 |
Morgan Jones wrote about valve heat sinks in Building Valve Amplifiers (The blue book)
I dont have the book to hand at the moment but I think I remember him quoting some source saying that just keeping the envelope temperature down can extend life. I can see that radiated heat from the anode would be partly absorbed by the glass because it does not completely pass IR. Also the black anodising on the heatsink will absorb the rest of the IR and as long as it has enough surface area for conduction/convection to the air will prevent heating of other devices around it. I think I saw some the same as in the book at Ask Jan First. The Pearl ones look good if a bit pricey. What tubes are you cooling Wavebourn? Matt. |
#10 |
6С19П
It looks better above SOA, on higher than specified voltage, with higher load resistance than usual. http://cqham.ru/tubes/soviet/pdf/6s19p.pdf
| FS: 2 Tung-sol 45 tubes, 2 Westinghouse 5u4gb tubes | athos56 | Swap Meet | 0 | 3rd August 2010 11:18 PM |
| Intel CPU heatsinks as power output transistor heatsinks? | deltavektor | Solid State | 4 | 29th November 2009 01:47 PM |
| FS Heatsinks, tubes, drivers and amps. | eapavant | Swap Meet | 9 | 29th April 2008 01:00 AM |
| CV428 tubes (Loktal 807) tubes FS | mobyd | Swap Meet | 3 | 2nd January 2008 11:26 AM |
| Caps, xformers, rectifiers, heatsinks, Zen PCBs, tubes and jacks | krikor111 | Swap Meet | 13 | 15th February 2005 02:42 AM |
| Page generated in 0.10732 seconds (75.42% PHP - 24.58% MySQL) with 11 queries |
