diyAudio Sponsor
Old 8th December 2010, 05:36 AM   #1
Default anyone help convert dual volume to single?
This tube pre has independent l and R volumes. My power amp also has dual volumes so I'd rather just convert this pre to a single volume setup. Can anyone take a look at this pic and guide me towards this end?
thanks in advance.
fyi, this circuit is basically a marantz 7c
Old 8th December 2010, 05:47 AM   #2
picowallspeaker's Avatar
Remove both single potentiometers and replace them with a double one of the same resistance and slope (logarithmic , I guess ) .
Put a red neon lamp to cover the hole of the lost pot .
Is it a joke ?
Old 8th December 2010, 10:46 AM   #3
Loren42 is offline Loren42  United States
Is it a joke ?
The second hole is where the balance control goes. So, he needs to understand how to add and wire up a balance control to the circuit.
There are two ways to do that. One is using a dual ganged pot. The ganged pot is wired similar to the ganged volume control, with one side grounded and the other connecting to the signal in. The wiper is the signal out. The ground side of the ganged pots are mirrored so that when you turn the pot one direction it increases volume of one channel and grounds the signal in the other. They make special tapers for these pots if you want to get exotic.
The other is a single pot with the wiper tied to ground and each end tied to the signal of the left and right channels. This pot needs to be a linear taper.
Old 8th December 2010, 11:55 AM   #4
Here are some ideas on rewiring your amp.
All pots are considered UP to be turning the pot clockwise in the schematic.
Dashed lines indicate a dual ganged pot.
Lin = Linear Taper, Log = Logarithmic Taper, and S = S Taper.
There are other ways to do this, but this will get you started.
Old 8th December 2010, 12:25 PM   #5
Did it Himself
richie00boy's Avatar
Just to make this clear - balance control is not needed to convert to single pot. Post #2 is what I would do, balance controls are useless and you have the ability to change relative levels on the power amp in this case anyway.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 8th December 2010, 12:33 PM   #6
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Originally Posted by richie00boy View Post
Just to make this clear.... Post #2 is what I would do...
If you want to keep it simple, I wouldn't worry about a balance pot. Just go with a dual ganged volume pot such as this one Partnumber=023-650 from Parts Express. Not sure what value you would need, but PE has other values as well. You can also get one at Radio Shack.
Mike
Marantz PM8003 amp, Squeezebox Touch, DIY Krystals
Old 8th December 2010, 06:47 PM   #7
tomchr is offline tomchr  United States
tomchr's Avatar
A balance control would cover up the hole in the faceplate nicely, though...
~Tom
Old 9th December 2010, 12:07 AM   #8
The current pots are 250k. So I should get a dual 250k and wire it up the same as it is now? including the jumpers on the left tab(s)
No balance needed as my power amp serves this function. thanks
I have two 500k dual pots handy. Would one of these work? One reads D500k and the other A500k. The current pots read B250k. I assume the A and D mean something? Not sure if either of these dual pots are log or audio.......?
Old 9th December 2010, 12:27 AM   #9
mikje's Avatar
I would try to get a 250K, but you can use a 500K for now. Yes, wire it up like it is now.
Enjoy your amp!
Mike
Old 9th December 2010, 01:05 AM   #10
danielwritesbac's Avatar
Wow, no problem! Your on-hand parts are perfect.
Here's Rod Elliot's take on volume + balance control: ESP - A Better Volume Control
Dual pots, both 500k will make a parallel pair of 500k loads makes 250k!. . . if you use one for balance and one for volume.
The A500k is the volume pot.
The B500k is the balance pot (one channel reversed on the pot itself makes balance pot--simply linear pot and when one channel turns up the other channel turns down).
Together, they make a 250k load. Well, I'm excited!
Its awesome that you already have the needed parts on hand.
Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? IG81 Multi-Way 3 4th February 2010 02:48 AM
How to convert S5 K-12g kit to dual mono? downward_dog Tubes / Valves 4 11th January 2007 12:57 PM
How should I convert my single Fe103 based RS speaker to a portable sound device? Spasticteapot Full Range 2 16th October 2006 03:56 AM
Convert single to dual supply Wombat2 Power Supplies 19 17th July 2006 02:44 PM
Can Any One Tell Me Please If These Chips Are Dual Or Single NAP 160 Parts 4 4th August 2002 10:03 PM
Page generated in 0.10404 seconds (81.71% PHP - 18.29% MySQL) with 11 queries
