Triode plate resistance == internal negative feedback? - Page 6 - diyAudio
Old 8th March 2011, 01:28 PM   #51
ruffrecords's Avatar
Originally Posted by SY View Post
When you don't make a tube with an rp of 60-70k drive a 100k load, the linearity (not surprisingly) is 10-20 times better than that.
That's the point of using a mu follower.
Interestingly, in a test where the tubes weren't asked to drive a heavy- for them- load, the no-name ultra short plate 12AX7 (innards look like 12AT7, Eastern European source) tested as well or better than the much-vaunted smooth plate Telefunkens.
Can you provide figures and describe your test circuit?
I'm surprised that the 6CG7 doesn't do better than that.
Morgan Jones in his tests with a CCS load got figures only 3dB better than this for the intrinsic distortion in a 6SN7. Most tubes do worse.
The good thing about a 6SN7 is that it does as well driving a 10K load but the 12AX7 obviously does not.
Cheers
Ian
Old 8th March 2011, 01:36 PM   #52
DF96 is offline DF96  England
Oops, sorry, I had a senior moment. When you said mu follower, for some reason my brain thought anode follower.
With the mu follower, the distortion depends on load impedance so you would need to check that you had not inadvertently favoured one valve type.
Old 8th March 2011, 01:43 PM   #53
SY's Avatar
Guess That Tube
Also, see post 52 in that thread.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th March 2011, 03:15 PM   #54
Guess That Tube
OK, that ties up well. Since distortion is directly proportional to output level your 8.5V rms is -7.5dB relative to my 20V rms. I got 2H at -60 which means at your level I would get -67.5dB cf your -70db. And as I said before, the mu follower seems to be no more than 3dB worse than a CCS.
So, the key question is exactly which 12AX7 was it you tested?
Cheers
Ian
Old 8th March 2011, 03:22 PM   #55
SY's Avatar
Did you look at the other post I referenced? That gave results at close to 20VRMS out.
That particular spectrum was from a Telefunken. As I said in the thread, the tiny plate Eastern European versions gave me almost the same results (within a dB or so).
Old 8th March 2011, 04:27 PM   #56
Yes, you got -65dB 2H cf my -60dB so that's a bigger 5dB difference - more than I would have expected.
Which does not tally with my tests where the small (less tall) plates gave distinctly worse results. That said I only tested two tubes of each type all current production. I also tested a couple of EH 12AX7 WA and one gave the amazing result of -68dB 2H at 20V rms - but this was at the expense of higher 3H. I am not quite sure what I was seeing there but I have noticed some other tube examples that have a better/worse 2H component accompanied by a similarly worse/better 3H component.
You mentioned the effect of mu follower load on distortion. This is quite true but also seems to exhibit this trade off between 2H and 3H.
For example, I tested some 6CG7 at 20V rms into loads varying from 100K down to 10K. At the extremes the 2H was identical but 3H increased by about 10dB at 10K load. There was a pronounced 2H minima of several dB at 15K load but again at the expense of 3H (although THD was also at a minimum). Generally from 100K load downwards to 15K, 2H decreased at the expensive of 3H (though THD decreased too) thereafter both increased. I also measured higher order harmonics which were not present at the 100K load but began to appear with heavier loads. I repeated the tests at 10V rms and there were no higher harmonics than the 3rd detectable at any load.
Cheers
Ian
Old 21st July 2016, 10:07 PM   #57
hpeter is offline hpeter  Slovakia
hpeter's Avatar
Originally Posted by smoking-amp View Post
Anyone know why the D3a is so revered for linearity in triode mode?
What i find common on hi linearity tubes like 6e5pi, D3a,C3m,(6h1p) is the obvious distance p-g and having flat plates pieces.
See, no plate at the sides, where grid bars are. Rather a openings. Maybe electron beams around gridbars are "dirty", distortion rich
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+µfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 STAX SR007 # LL2748 > 394A > LCLC 4H/100µ
Old 21st July 2016, 11:06 PM   #58
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Yes. Uniform field. Consider a tube as a multiple tubes with different parameters in parallel and take an integral. Planar tubes are winners. As well as tubes with strictly concentric electrodes.
Also, tubes with longer electrodes and denser grids like 6P15P are more linear than tubes with shorter electrodes and rarer grids like 6L6, it was designed for video amplifiers in TV, based on already existing EL84 design.
I expect if to make a version of GU-50 with at least half longer electrodes it would be a killer 60W tube for audio. But it was designed to work in mobile equipment, that's why it was so relatively short. RCA for mobile RF equipment designed, for example, 832 that resembled 2 of 6L6 with very short electrodes in a single envelope.
The Devil is not so terrible as his math model is!
PSPICE and negative resistance rtarbell Software Tools 2 16th May 2009 09:34 PM
NPN negative collector resistance?? darkfenriz Parts 7 16th September 2007 06:45 PM
Automotive relays and internal resistance? pjpoes Everything Else 2 9th February 2007 05:18 PM
Two port negative resistance element rtarbell Parts 9 18th March 2006 10:27 AM
811A tube internal resistance ? Zoran Tubes / Valves 38 11th May 2004 08:33 AM
Copyright ©1999-2017 diyAudio
