| diyAudio Sponsor | ||
So....Gurus and others.
1. Which tube do these curves belong to? 2. Do the curves indicate a linear tube? 3. Would you use it for a PP amp or a SE amp? |
#2 |
I think it is very hard to tell if you dont give any numbers
Real tubes have top-caps |
#3 |
I don't want to make it too easy. But ok. 20 mA/div vertical and 20 V/div horisontal. I aint saying nuttin bout grid voltages yet.
#4 |
Volt/ampere diode characteristics on different filament currents?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 |
Regulator triode, low voltage and high current capability.
#6 |
It reminds me of EL36 in triode, but the voltages dont work out
#7 |
Is that hysteresis I see?
Never send a human to do a machine's job. --Agent Smith |
#8 |
2A3
#9 |
6AS7! Not bad Gimp.
Mohahahaha! U guys keep up the 'it's so nonlinear' and let me have all the fun. Keeps the price down. |
#10 |
Looks like you only have 20 Volts of grid change on that earlier plot. Here's the rest of the curves:
Plotting most any load line on them shows a 2 to 1 change in gain from one end to the other. Umm... 100 % distortion? Probably work OK in P-P though, where all that 2nd Harmonic would cancel. edit: added curve trace of a low distortion triode for comparison (not a 300B, this only costs $3)
Ohms Law V = I R Last edited by smoking-amp; 10th March 2011 at 02:41 PM. |
| Yet another Lowther cab quiz | brownie | Full Range | 17 | 3rd June 2009 03:51 PM |
| Interresting Quiz. Which tube is this? | Radioman62 | Tubes / Valves | 5 | 28th December 2008 12:41 PM |
| Pop Quiz | keantoken | Solid State | 3 | 15th June 2008 10:05 PM |
| a quiz about AC power | vax9000 | Tubes / Valves | 75 | 28th July 2006 10:58 AM |
| Group Quiz | JRKO | Music | 6 | 23rd January 2005 05:14 PM |
| Page generated in 0.07904 seconds (86.01% PHP - 13.99% MySQL) with 11 queries |
