Mengyue Mini EL34B stereo balance issues..
Old 15th December 2010, 08:27 PM   #31
kevinkr's Avatar
Originally Posted by chops View Post
No, it's NOT the laptop as I said before. It even did it in my system, and there's no laptop in my system. It's even done it just by turning the amp off for a minute then turning it back on. If you read my post a couple posts back, you would have known that.
Not only that, why on earth would the settings in the laptop magically change on their own simply by swapping cables?!
My comment was predicated on the fact that usually when you swap source connections and the problem follows the swapped cables that there is a problem with the source. (20yrs+ of audio engineering experience has at least taught me that.) Yes I did miss the post where it behaved the same way in your system. Obviously something else very odd is going on here. My comment about the laptop mixer controls did not imply that they magically or otherwise changed when you swapped the cables, it was a suggestion to check.
Good luck...
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Mengyue Mini EL34B stereo balance issues..Hide this!Advertise here!
Mengyue el34b schematic needed me32dc Tubes / Valves 2 9th March 2010 07:02 PM
mengyue mini valve amplifier whats gan on Tubes / Valves 15 5th December 2009 04:13 PM
HK330A Stereo Beacon Issues DreadPirate Solid State 6 9th December 2007 05:32 PM
how do i solder a stereo mini plug? ffrr Parts 3 17th June 2006 01:53 PM
FS: 10k Goldpoint Mini-V (Series-type) Stereo Attenuator Strohmie Swap Meet 3 19th October 2005 10:39 PM
