#11 | |
Either your cables or your sound card/laptop setup are the problem here. Try an input from a dedicated CD player and new cables and let us know the results. |
#12 | |
If that is the case, could it be possibly unmatched tubes? Does the system use separate tubes to drive each channel, ie one 5751 for each channel? If it does, then the 5751 seem suspect as your 12AX7 seem to work ok. The overdriving might be happening due to the higher mu of the 12AX7 compared to the 5751 leading to "clipping" of the driver stage. |
#13 |
I think you are going to have to get a look at the output of both channels on an oscilloscope. What you describe could be a high-frequency instability which is swamping the one channel (and instabilities can be random like this) and making it seem to go low or distorted. The PCB layout and build quality that I saw on their 6P1 amps leaves a lot to be desired, and with tubes like EL34s it could be a recipe for instability.
#14 | ||
With his Mullard 12AX7's installed, I don't really think they are getting overdriven. If that was the case, he would have been getting distorted sound all along with this amp. It only got that distorted sound today after swapping my 5751's out for the 12AX7's. Quote:
What exactly could be causing that "high frequency instability" you are speaking of? Is it a flaw in the design, something wired wrong, or some components used with wrong values or something? In order to view this amp's output on an oscilloscope, he's going to have to take the amp to our father so he can check it out on one of his oscilloscopes. I have no clue when it comes to using one of those. |
#15 | |
The alternative comes down to reflowing the solder on the PCB and hope ![]() An oscilloscope with a knowledgable operator is really your friend here. Gary |
#16 |
The amp is not standard if it accepts 5751 or 12AX7, so the previous owner has been in there doing "stuff". What's the chance of a close-up pic underneath? (bottom cover removed) The PCB traces for heater power will at least have been hacked/modified. You brothers must be a "chip off the old block" (as we say in Australia) with tubes in the blood.
#17 |
The standard (unmodified) Mengyue Mini EL34 uses a 6n2 for the front end tube, with no DC blocking cap on input. Any DC coming from the source computer (leaky output electrolithics perhaps) can upset the DC bias of the front end tube and can cause weird results.
My sugegstion would be to fit two good quality 33nF capacitors in series with the two leads coming from the pot wiper (where they are soldered to the main PCB), see if this makes any difference. The 6n2 is a 12AX7 type tube, only the heater is 6.3V to p4-p5, so to use a real 12AX7 or similar the socket needs to be rewired. /Tibor |
#18 | |||
And yes, all of us have always loved and have had tube amps at some point in our lives except for one other brother of ours. I don't think he ever got into them. Then again, his systems have always been sub-par so to speak, so it doesn't surprise me that bit. LOL Quote:
Pot wiper I am assuming you mean the volume pot? |
#19 |
Not to be too pedantic, but that is a common misconception. It is true that all the 12**7s share the same pinout but their operating characteristics are different: that's why they are given different nomenclature.
In fact, the 12AX7 and 5751 operating parameters are different, just as the amplification factor, plate resistance, and transconductance are different. For instance at Vp = 100 and Vg = -1 the 5751 will draw 35% more current than the 12AX7. That's clearly not related to your problem, but it is also clear that they differ in more than just amplification factor. |
#20 | |
Gorgomat's version: Meng Yue Mini schematic? jeff |
| Mengyue el34b schematic needed | me32dc | Tubes / Valves | 2 | 9th March 2010 07:02 PM |
| mengyue mini valve amplifier | whats gan on | Tubes / Valves | 15 | 5th December 2009 04:13 PM |
| HK330A Stereo Beacon Issues | DreadPirate | Solid State | 6 | 9th December 2007 05:32 PM |
| how do i solder a stereo mini plug? | ffrr | Parts | 3 | 17th June 2006 01:53 PM |
| FS: 10k Goldpoint Mini-V (Series-type) Stereo Attenuator | Strohmie | Swap Meet | 3 | 19th October 2005 10:39 PM |
