My Project:  Pilot 602
Old 13th December 2010, 03:42 PM   #11
Eli Duttman is offline Eli Duttman  United States
Specialty brushes for cleaning tube sockets are available, but they're somewhat pricey. A periodontal brush from the "drug" store works well on 7 and 9 pin mini sockets.
DeOxit yes, vinegar no!
Eli D.
Old 6th June 2017, 06:46 PM   #12
jackinnj is offline jackinnj  United States
jackinnj's Avatar
The Pilot 602 has a "Press to Test" feature -- i am guessing that you turn the DC bias pot until no "click" is heard when the PTT is pressed.
Old 7th June 2017, 05:23 PM   #13
jackinnj's Avatar
Interesting find, the center tap of the output transformers are wired to the screen grid pin of the 6BQ5's. This means that the screen potential might even be higher than the anode. Apparently, someone forgot to tell the soldering mavens that the red-yellow wire was to be connected to the junction of the 100R/40uF capacitor.
Diodes replaced with UF4007, so will pick up ~4V.
All the can electrolytics are shot, so replaced with new.
100R 10W resistor replaced with a Caddock affixed to the chassis -- this will remove some of the heat from the under-compartment.
Old 8th June 2017, 03:54 AM   #14
PRR is offline PRR  United States
PRR's Avatar
This is Not A Problem.
These are pentodes, not True Triodes.
Old 8th June 2017, 03:43 PM   #15
jackinnj's Avatar
Not a big problem, but it in simulation it worsens THD by ~2.4dB.
Will have to measure. Just jumper the 100R resistor.
Old 19th June 2017, 04:31 PM   #16
jackinnj's Avatar
C2 is now replaced with 3x 47u/350V electrolytics, R117, R118 replaced with Dale 2.5 watters.
Old 20th June 2017, 12:43 PM   #17
jackinnj's Avatar
Finished up C3 last night -- replaced R116 -- a 10K 2W showing signs of fatigue with a 10K Caddock affixed to the chassis. R119 100R 10W replaced with a 100R caddock also affixed to the chassis.
Old 21st June 2017, 01:33 AM   #18
jackinnj's Avatar
First tests -- had to replace one of the ECC83's, the bypass caps from the phase splitter were replaced with 0.1u/630V Panasonic polypropylenes as the old film caps were leaky. One of the DC balance pots was completely shot and replaced with a spare CTS unit found in the junk box.
1W, 1kHz THD 0.1%
I think that the 100uF cathode bypass cap has to go...
Old 21st June 2017, 02:25 PM   #19
jackinnj's Avatar
Cathode resistors on the 6BQ5's are running really hot -- they are carbon comp 1W 330R, but are pumping close to that already. (yes, there was smoke before I replaced the 500R DC balance pot!)
New blocking caps after the phase splitter:
Old 29th June 2017, 04:45 PM   #20
jackinnj's Avatar
New Panasonic ECG 330R resistors in the cathodes, new DC balance pot, replaced the cathode bypass electrolytic cap with 100u 100V Muse. Some results:
My Project:  Pilot 602Hide this!Advertise here!
pilot light ideas please gary h Tubes / Valves 3 30th July 2008 03:48 AM
Pilot SA 260 bias baltimoreblues Tubes / Valves 1 3rd February 2008 06:00 PM
magic smoke pilot aa903 coyotesgator Tubes / Valves 12 27th December 2007 12:41 PM
Pilot Lamp Draws Too Much? CarlosT Chip Amps 1 27th December 2006 04:21 PM
pilot 264 jaron Tubes / Valves 17 13th March 2006 03:32 PM
