Super cheap triode amplifier
Old 22nd November 2012, 03:09 AM   #71
tcqanh is offline tcqanh
Originally Posted by aldovan View Post
No problem.
I working now, but when I arrival in my house, I will post my simple driver solution...not the best, but work fine...
Aldovan
waiting for your schema with 3C24.
some tubes are born to be able to play with pink plate . maybe 3C24 is in that group
Old 22nd November 2012, 09:16 AM   #72
MrCurwen is offline MrCurwen  Finland
3C24 has a shorter lifespan if plate is not operated red.
Old 22nd November 2012, 09:37 AM   #73
Burnedfingers is offline Burnedfingers  United States
Originally Posted by ikoflexer View Post
I'd like to see only how you drive the output tubes. I'll play with something like that myself, maybe. There's a lesson to be learned in all of this.
I hope that lesson doesn't include switching to cardboard speakers. I can just feel the bass
Old 22nd November 2012, 09:42 AM   #74
aldovan is offline aldovan  Brazil
Yes, the Eimac and HK recommended use with red plate because the plate work as a "getter" and absorb the oxygen.
Old 22nd November 2012, 09:47 AM   #75
No, in the video I play a simple BR with a Utah alnico speaker:
https://www.youtube.com/watch?v=67J3...hannel&list=UL
Old 22nd November 2012, 09:50 AM   #76
I think he was just kidding.
Me like the red plates! Big time!
The 15E play fine, too.
My problem is find the socket...
In the video I use a ceramic bridge for power electric use.
https://www.youtube.com/watch?v=EAR2...feature=relmfu
Sorry for brazilian music....
Aldovan
Old 22nd November 2012, 02:39 PM   #77
iko is offline iko  Canada
iko's Avatar
Good way to prototype, I must say!
Old 22nd November 2012, 02:41 PM   #78
iko's Avatar
Aldovan
The 15E seems harder to find. I have a good stash of 4E27, so that's going to be the output tube for me. Problem is... winding my own output transformer.
Old 22nd November 2012, 02:49 PM   #79
Why you do not to buy the transformer ?
The Hammond in your country have a line of very good hifi output transformers( but not the 125E or 125SE, please).
Aldovan
Old 25th November 2012, 06:23 AM   #80
azazello is offline azazello  Bulgaria
azazello's Avatar
Tony,
The point I was trying to make is you cannot tell very much about speaker response the lack of detail or any improvements to a circuit when you listening to speakers mounted in a cardboard box.
Aldovan,
Are you talking this transformer?
GXSE10-8-2.5K
10W, single ended tube output transformer for 2.5K Ohms to 8 Ohms.
I have not used this transformer but I do have on hand two Hammond 125ESE's still new and in the box. If I'm going to build this little amplifier I will not depend on it to try to reproduce low frequencies. I will instead hook up a simple little subwoofer. This is why the Hammond 125ESE transformers I have will work fine. They are somewhat limited in their low frequency response and this will mate up fine with a small subwoofer with the frequency at a maximum of 80-100HZ @ 24db crossover.
I'm not agree about LF of H 125SE. 5-6 years ago seller offered this cheap tr. for SE 2A3, 300B, 6L6...I tried 300B with 125FSE and Freeq. band was more 20-30000 Hz with the sames amplitudes /+- 0 db!/. Now I don't believe that band is 70 or 150 - 15000 Hz . I don't understand seller's deals.....
Super cheap triode amplifierHide this!Advertise here!
Has anyone here built something with this super triode? Molloy Tubes / Valves 11 18th February 2018 07:22 PM
Super Triode Connection Amplifier Build with 6BM8 and 6AK5 DerFly Tubes / Valves 35 3rd November 2009 07:45 AM
Super Triode Conection amps - opinions needed Petman Tubes / Valves 2 25th October 2003 01:00 AM
