#21 | |
The output transformer Is made in a transformer factory here in Brazil. I make the calculus and the industry build for me. But I will get a Edcor GXSE10 for a comparation... Aldovan |
#22 |
Hi, where did you get the grid curves for triode operation of the 6j9p?
#23 |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#24 |
Ok thanks!
#25 |
Super cheap...?
1. Change E180F to 6AU6, there's boatloads of these around and the price is good. More abstract choices abound, especially oddball triode-pentodes. Nothing wrong with letting one half of such a device go unused, if you only need one. And hey, you could add a "tube roll" switch (at moderate price increase) to change between the triode and pentode in the envelope! 2. Replace LED with resistor. LEDs cost money. 3. Don't parallel caps: besides being a useless procedure, they waste space. Additionally, don't use name-brand capacitors; end-users know the sellers simply pump up prices artificially on components that have no audible effect whatsoever. I haven't seen many capacitors any cheaper than Cornell-Dubilier DME series, plus, they're really, really compact. Absolutely perfect for coupling use. 4. 6W6 is an oddball choice, but makes a reasonable triode. Prices may vary. 6V6 would be more common, and is in current production [I think..??], but price varies accordingly with market. YMMV. Rolling options include... pretty much any comparable pentode, certainly the 6Y6 mentioned, but also 6K6, 6F6 (a bit lower gain), higher voltage variants like 12L6, and even miniature variants thereof, like 50C5, etc. 5. The output transformer isn't specified, but do make sure to grudgingly spend a couple bucks there, you won't regret it. 6. Dump the series choke, it's expensive dead weight. Yeah it makes things quieter, but the thread title is "Super cheap amplifier" after all!! All right, you probably do want the choke in there, but only grudgingly. 7. We've already got silicon diodes, dump the damper. Also, less filter capacitance could be used, at expense of ripple levels. Tim |
#26 | |
i suspect that in a hi-fi amp, they will sound good....
http://www.elab.ph/forum/index.php?topic=32688.0 |
#27 |
Use two parallel interstage caps /1 uF and 330 nF/ with different structure is not good idea. It decrease quality of sound in M and H freeq., because small AC current across different media. Please, check with only one of both caps and listen carefully.
#28 |
I would like to see it with a 6Au6 or 6Sj7. A cathode resistor instead of an Led. Loose the choke, keep the damper tube and I don't think it will make it sound tubey but I like the slower warm up. Use a cheap Hammond 125 transformer and loose the paralleled caps. I have some 6W6's in my tube caddy to try.
http://dynaco2forum.forumsmotion.com/ |
#29 |
I think I would have decoubled the 6W6 cathode resistor(s)..
Life is hard - Then you die. |
#30 | |
A led cost cents...if I remove the damper, the choke and the others components, the quality down a lot. Them is best use no power transformer and connect direct to 127V using tubes with 50V FILAMENT. The hammond 125 is very bad in frequency response... My friend, you probabily is a silicon amplifier user...
| Has anyone here built something with this super triode? | Molloy | Tubes / Valves | 0 | 12th January 2010 01:04 AM |
| Super Triode Connection Amplifier Build with 6BM8 and 6AK5 | DerFly | Tubes / Valves | 35 | 3rd November 2009 07:45 AM |
| Super Triode Conection amps - opinions needed | Petman | Tubes / Valves | 2 | 25th October 2003 01:00 AM |
