Super cheap triode amplifier - Page 10 - diyAudio
Old 4th December 2012, 04:02 AM   #91
Mosquito's Avatar
Aldovan, I like your amp and truly appreciate your "sleeper tubes" findings, but I suggest you to capture your sound clips trough the microphone incorporated in Your PC earphones, and record it in a cassette recorder boombox, on a type "D" TDK, and then share it. This probably would be a whole lot nearest to a tiny fraction of high fidelity, than the "sound" of a YouTube video..
"It is less serious than if worst"
Old 1st March 2013, 09:42 PM   #92
Hi Aldovan,
I built a parallel single-ended version using 12W6 with a 6N1P driver. Sounds very nice. Thanks for the idea!
Scott
Old 2nd March 2013, 04:23 PM   #93
aldovan is offline aldovan  Brazil
Originally Posted by scott17 View Post
Hi Aldovan,
Scott
Scott
I'm happy for you like the results.
I do projects with forgotten tubes and have nice surprises...
My last project was with the tetrode 865 in triode mode and the sound is as good as a 2A3... if you find some pieces , get it!
RCA 865 in triode mode single ended class A - YouTube
I am now doing a project of an amplifier for more power, with another pentode forgotten and then I'll post here!
A hug and good fun!
Aldovan
Old 2nd March 2013, 05:35 PM   #94
Hi Aldovan,
Scott
Scott
Only more one information...the E180F or 6J9P will sound better.
If you can obtain one, you will listen the difference !
Aldovan
Old 2nd March 2013, 10:33 PM   #95
Do you run the E180F driver triode strapped?
Originally Posted by aldovan View Post
Scott
Aldovan
Old 2nd March 2013, 10:38 PM   #96
TonyTecson's Avatar
the Russian 6J9 sells cheap and is good sounding, i used it in pentode as input tube in place of the EF86...it has more gain than the 6N1p...
triode test results for a Raytheon 6688......
Raytheon 6688 : G2 connected directly to A : G3 connected to A with 100R : Vh = 6.3V
At 150V/16.6mA, Gm = 17.6mA/V and mu = 60, Rp = 3.4k : Plim = Pa 2.7W + Pg2 = 0.6W
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 3rd March 2013, 12:30 AM   #97
I will try the 6J9.
I am very impressed with the the 6N1P in parallel however.
Thanks.
Old 3rd March 2013, 12:36 AM   #98
Yes, in triode mode !
Old 3rd March 2013, 12:49 AM   #99
The E180F = 6J9P
Old 25th May 2014, 01:17 AM   #100
maton00 is offline maton00  Mexico
maton00's Avatar
Send a message via MSN to maton00
Hey aldovan do the woofers in the 25L6GT video are the Aura NS6-255-8A?
Those are good also very sensible speakers those do make a lot of noise with a watt or so.
Has anyone here built something with this super triode? Molloy Tubes / Valves 0 12th January 2010 01:04 AM
Super Triode Connection Amplifier Build with 6BM8 and 6AK5 DerFly Tubes / Valves 35 3rd November 2009 07:45 AM
Super Triode Conection amps - opinions needed Petman Tubes / Valves 2 25th October 2003 01:00 AM
Copyright 1999-2017 diyAudio
