diyAudio Sponsor
Old 2nd December 2010, 06:14 AM   #1
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default JC Morrison circuits
Last weekend was the European Triode Festival. There's some reports from the (all tube) events here:
European Triode Festival 2010
JC Morisson, currently a designer for Silbatone in Korea, had a presentation with several unusual but creative tube circuits. Another ETF attendant put these on-line here:
(new adventures in) ultra‐fi: new stuff from jc morrison
Enjoy!
jan didden
/Another new issue: Linear Audio Volume 3!
Old 2nd December 2010, 06:26 AM   #2
frugal-phile(tm)
planet10's Avatar
Thanx for that Jan...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd December 2010, 06:51 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Hi Jan;
Do you mean CCS loaded pentode? How well it drives grid currents and Miller capacitances?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 2nd December 2010, 08:57 AM   #4
janneman's Avatar
Originally Posted by Wavebourn View Post
Hi Jan;
Hi Anatolyi,
I have no expreience with these circuits, but they look different and innovative so that's why I posted the link here.
Apparently they are used in the no-holds-barred Silbatone equipment.
JC specifically said he wanted them out in the open to avoid some 'smart' guys to patent them.
jan didden
Old 2nd December 2010, 09:57 AM   #5
Wavebourn's Avatar
Originally Posted by janneman View Post
Hi Anatolyi,
Smart decision; I often do the same!
I am going to publish Vostok solid state assisted tube amp soon...
I'm still breadboarding it, to explore all possibilities.
It is kind of new replacement for SRPP, with some better qualities.
Old 2nd December 2010, 11:06 AM   #6
SY's Avatar
Nice to see someone out there being creative for a change. Now, if you combined that pentode circuit with Frank Bloehbaum's hybrid screen setup...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 2nd December 2010, 11:17 AM   #7
revintage's Avatar
Even if the the circuit is DC-connected from input to output, it still must be AC-connected signal-wise as C1 shorts the CCS.
About innovative circuits at ETF, Frank (Blohbaums?) Gm-circuit really should be mentioned. Used in his presented phono-amp.
Brgds
Lars
Old 2nd December 2010, 11:31 AM   #8
janneman's Avatar
I understand the two are talking a lot.... (to each other).
jan didden
Old 2nd December 2010, 01:26 PM   #9
DF96 is offline DF96  England
I'm not quite sure what the point of these inverted circuits is. Have I missed something?
If your first stage has a very high output impedance you had better be sure that your second stage has a very linear input impedance and very low Miller capacitance. Also very low heater-cathode leakage in the first valve, even with a DC heater, as this appears in parallel with the output unless you bootstrap the heater supply reference voltage. There is a reason why, until recently, most people used the classic simple circuits - and it was not ignorance!
Old 2nd December 2010, 02:22 PM   #10
Gary Pimm shows some work on CCS loaded pentodes, and I have recently seen a power amp schematic somewhere showing exactly the same concept. So Mr Morisson himself, or anybody else willing to burn up some money, could probably still apply for a USPTO patent, maybe even get it, but it would never survive a trial process if someone was willing to challenge it (I don't know the exact terms in English).
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Looking for Jim Morrison Siren Song preamp schematic phrarod Tubes / Valves 44 22nd March 2009 12:13 AM
Minimalist preamps - Morrison, Samuals?? amt Solid State 41 7th January 2007 09:51 PM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 12:50 PM
85 powersupply circuits 58 charge circuits gev Power Supplies 0 31st July 2005 11:27 AM
Page generated in 0.10218 seconds (83.80% PHP - 16.20% MySQL) with 11 queries
