Strange Grounding Problem - My best guess: ghosts. - Page 4 - diyAudio
Old 29th November 2010, 09:36 PM   #31
Originally Posted by M Gregg View Post
I have to sign off now!
I am sure there will be others who will carry on! Catch you later!
M. Gregg
Thank you very much for the help!
Old 8th December 2010, 12:34 AM   #32
The unit finally started acting up again and there is a corresponding voltage problem from the PSU
Input 220 vac
output 226 on the - rail
output 23 on the + rail
The + rail during normal operation produces 222
There is the problem!
When taking the PCB out to take more measurements it started working again, so i couldn't narrow it down.
I'm guessing I can track the 'bad' AC voltage back into the power supply, see where it changes (at what component), then replace that bad component?
Old 8th December 2010, 01:09 AM   #33
RIP
pedroskova's Avatar
...bad solder joint on the "+" side in your psu?
What happens to your circuit if one or both of your zeners goes on the fritz?
Help with a grounding problem bigpigbig Analogue Source 2 4th December 2009 08:55 PM
Grounding problem? Bas Horneman Tubes / Valves 16 5th September 2008 03:33 PM
grounding problem..need help jegandren Power Supplies 13 30th July 2008 02:52 PM
Strange problem with this wiring/grounding scheme Leolabs Chip Amps 2 17th April 2007 09:59 AM
Strange little problem (or maybe not so) elizard Chip Amps 8 4th January 2004 06:25 AM
Copyright 1999-2017 diyAudio
