| diyAudio Sponsor | ||
So, I have build a couple of SE stereo amplifiers using the ECL85. I will include the schematic for what I have currently. What I want to do is essentially use all the same transformers, choke, and power supply and substitute 6v6 for the pentode and a 12AT7-WA (I just have a bunch of these laying around) for the triode gain stage. I wanted to see if anyone had some experience running the voltage that low on the 6V6 and my power transformer is going to limit the current available for the power stage to about 30ma per channel (worked out just fine for the ECL85 but I think it is not going to be enough for the 6v6). Thoughts?
#2 | |
Since the available current is limited, the output power will stay at the same level ( about 3 W ?) as with ECL85. There seem to be absolutely too small cathode bypass capacitors at the pentode, only 6 uF. This will limit the bass response. Put min. 100 uF instead and you hear the difference. |
#3 |
You need for heating 6V6 and 1/2 12At7 about 0.6-0.7 A per channel.
And 50 ma +B per channel, 6V6 works good with 40-45 ma - 280-300v., and 12AT7 with about 5-7 ma-180-200v. Suitable transformer for PSU is Hammond 269AX - I built the same ampl. few days ago. Last edited by azazello; 24th November 2010 at 05:22 PM. |
#4 | |||
Have very many people run a 6v6 at 200v (with the type of bias setup I have here) and about 30ma with success having a 6.6k ohm primary load to 13k primary ohm load? |
#5 |
Hammond 269AX has 250 v - 100 ma on secondary coil. /cost about 39 $/
#6 | |
#7 |
I use the Allied 6K56VG in my 6V6 Simple SE. It uses a 12AT7 for the driver. B+ is 325 volts using a 5AR4 rectifier tube. Probably around 350 volts with silicon. The transformer is $45 and is made by Hammond.
Search results for "6k56vg" - Allied Electronics
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#8 |
Or if you have another transformer that puts out 12v you could free up some of the iron in your existing transformer and not run the heaters off it. That may give you an added 25mA which should put you in the ballpark for the 6v6's. If you find you like it you can look at a permanent solution.
#9 |
Well, after going through thanksgiving and working through the design. I had a spare transformer that was a little larger that could handle the voltages a little better. Here is a schematic of what I ended up going with. I am still up for some modifications if someone has any. Also I have one correction to the schematic that I have drawn. I have a choke from the diodes to the first capacitor. The choke is 7H and 240ohm. Let me know what you think. I have also included a picture of the amp. Thanks in advance.
#10 | |
Couple of other comments; You could use separate cathode resistors at output tubes. This improves possible unbalance between tubes. Since your output transformers are not the best for 8 ohms load ( too high turn ratio) you could also add a light NFB, for example by connecting the secondaries of the output pubes in series with the cathode resistors, (and with correct polarity). Usually the linearity of the output stage is improved if some 470-680 ohms series resistor added between UL-tap and g2. |
| New Desktop Tube Amplifier, 6V6 SE | Musik007 | Twin Audio | 11 | 6th October 2010 04:23 PM |
| 6SJ7(6J8) + 6v6 (6P6S) SE | athos56 | Tubes / Valves | 4 | 23rd July 2009 07:24 AM |
| SE 6V6 cathode resistor value | bereanbill | Tubes / Valves | 7 | 24th May 2009 04:11 PM |
| 6V6 vs EL84 SE UL | AudioGeek | Tubes / Valves | 10 | 3rd February 2006 11:05 AM |
| turning a SE 6v6 to a 6bq5 amp | rvas18 | Tubes / Valves | 25 | 8th January 2004 06:29 PM |
| Page generated in 0.12064 seconds (82.97% PHP - 17.03% MySQL) with 11 queries |
