6V6 SE VS ECL85
6V6 SE VS ECL85
Old 9th December 2010, 10:35 PM   #21
Printer2 is offline Printer2  Canada
You know you can put capacitors in series.
Old 10th December 2010, 09:54 PM   #22
J_Hart_14 is offline J_Hart_14  United States
I finally go the high voltage stabilized I put a 500ohm resistor before 67uf cap. Now the voltage is sitting right at 380V or so on the plates. I went ahead and substituted in 1k ohm resistors for the cathode bias and they are pulling right around 30ma or so. I am going to go ahead and do more work with the feedback network this weekend. I will let you know the results.
Old 14th December 2010, 01:15 PM   #23
Thanks for those giving input and following. I ended up using a 3.9kohm resistor for the feedback network. When I get time this week I will update with the final schematic for what i have built. I will be giving a week long test at work.
6V6 SE VS ECL85Hide this!Advertise here!
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 04:23 PM
6SJ7(6J8) + 6v6 (6P6S) SE athos56 Tubes / Valves 4 23rd July 2009 07:24 AM
SE 6V6 cathode resistor value bereanbill Tubes / Valves 7 24th May 2009 04:11 PM
6V6 vs EL84 SE UL AudioGeek Tubes / Valves 10 3rd February 2006 11:05 AM
turning a SE 6v6 to a 6bq5 amp rvas18 Tubes / Valves 25 8th January 2004 06:29 PM
