How much would a cathode follower drift ?
Old 24th November 2010, 01:09 PM   #1
00940 is offline 00940  Belgium
00940's Avatar
Default How much would a cathode follower drift ?
In the following schematic, what kind voltage of drift should I expect at the output over time ?
The output would go into an output transformer that can't stand more than a few mA of DC current and I wonder if I should implement a DC servo (probably a copy of SY's Heretical).
Ben.
Old 24th November 2010, 01:42 PM   #2
DF96 is offline DF96  England
It will drift a huge amount. This is because for DC purposes the CF is not a CF at all but common-cathode with cathode bias. Without a DC servo there is little chance of the output ever being near 0V.
A DC CF would be better, but still not good enough if you want accuracy to mA levels.
Old 24th November 2010, 04:23 PM   #3
00940's Avatar
Thanks.
A servo is no big deal after all... it avoids the nightmare of matching a parafeed cap to the output xformer for best frequency response.
Ben.
How much would a cathode follower drift ?Hide this!Advertise here!
cathode follower vlljpior Tubes / Valves 6 22nd March 2005 08:50 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 04:12 PM
cathode follower olvrkrg Tubes / Valves 3 21st February 2004 10:49 PM
Copyright ©1999-2017 diyAudio
