plate to plate feedback - measurements - Page 4 - diyAudio
Old 26th November 2010, 03:16 PM   #31
Michael Koster's Avatar
Originally Posted by richwalters View Post
I tried this sometime ago using high transconductance unscreened tubes, the 6CL6,12BY7 gang, and with the minimal damping and excellent ft, self oscillation can be a problem. Beware of the layout using such gyrators with a near infinite AC load Z.
The feedback resistor connected to the output tube plate is an AC load and sometimes also a DC load for the driver pentode. It's very well controlled and I've not had any oscillation problems using 6CL6 or other high gm pentode.
I agree the thin sound and rounded 10 KHz square wave are not likely to be related except perhaps caused by a high output damping factor. Thin sound could simply be flat LF response. The square wave rounding could simply be your OPT response and gNFB would be needed to help out.
But what is the sine wave frequency response? Maybe the high end is good enough.
The driver voltage and current changes are not a bad move though. Gyrators wouldn't hurt either but none of that is likely to change the thin-ness or the rounding of the square waves at this point.
Michael
Old 26th November 2010, 03:53 PM   #32
hidnplayr's Avatar
Here is the open loop response of the amplifier (1watt) into a dummy load. (blue trace)
The black trace shows the result when I used an RC-network gNFB.
Transformers resonance is at 44,5 kHz
These where all measured without plate to plate NFB
Real tubes have top-caps
Old 26th November 2010, 04:18 PM   #33
hidnplayr's Avatar
Wow, it is starting to make sense..!
Red trace is with shunt feedback added and the gNFB through RC network.
The green trace is with shunt feedback and no gNFB.
If you compare it with the blue one, you'll notice the similarities and a little bell inside your head should begint to ring.
Now, how do i fix it ?
Old 26th November 2010, 04:47 PM   #34
Dingdingding
OK, the OPT peaking is increasing the NFB at high frequency, causing less gain.
I'm guessing (without detailed observations) that the peaking is much greater on the primary side as the P-S coupling decreases, resulting in greater effect on the feedback vs. the output, hence the greater loss with local feedback.
This could be the issue Sheldon is noticing as well.
The feedback or the OPT or both could be compensated. I'd be inclined to try a zobel across the OPT primary as an experiment.
Great work!
Michael
Old 26th November 2010, 04:51 PM   #35
hidnplayr's Avatar
So.. I added a load of gNFB no RC network this time (altough turning it upside-down might have worked..)
Black = open loop
Blue = with plate to plate feedback
Red = same as blue, but with gNFB
The other pics are square wave (1khz and 10khz) at 1 watt into the dummy load.
For the listening test.. I will need an additional gain stage!
Old 26th November 2010, 05:24 PM   #36
hidnplayr's Avatar
Now look what happens when I return on my steps and remove the gNFB and use 220k for the plate to plate resistors.. (green trace)
Remember, the red trace is the one with the load of gNFB.
Old 26th November 2010, 06:30 PM   #37
hidnplayr's Avatar
..So i replaced the 0.91µF capacitors I was using to couple the feedback resistors, with 47nF ones..
This creates LF roll-off in the feedback circuit, compensating the LF roll-off of the output Xformer..
(evil/genius plan, I leave it up to you to decide..)
Et voila!
No gNFB and pretty decent square wave response, even with a real speaker as load. Just like I wanted..
The green trace is that of the circuit I just described.
Old 27th November 2010, 05:17 PM   #38
hidnplayr's Avatar
The previous idea obviously was a stupid one, as it made the DF higher where you want it to be small, on the lower frequency's..
Another way, wich I'm testing now, is to make an arrangement with resistors, in baby huey style. And accross the resistor that connects the two phases together, I placed a zobel.
Now there is less damping in the highest frequency's, but the High frequency roll-off of the amplifier is much better then without the zobel..
Old 28th November 2010, 09:57 AM   #39
Originally Posted by revintage View Post
The driver should be run at as high current where it has its sweet spot, check curves. Go for a D3a or E280F at 150V/150V/20mA. Also add gyrators instead of anode resistors. MJK has shown elsewhere how it should be done.
Hi Revintage
I have followed quite a lot of the recent discussions on gyrators, but can't remember about them being combined with pentodes. Can you please provide me with some further details, a link, or some keywords to search?
Thanks, Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 29th November 2010, 08:52 AM   #40
Hey Erik,
This one made by MJK in an earlier thread says it all:
EL84 PP using 5K plate to plate primate OPT jmillerdoc Tubes / Valves 5 9th March 2010 09:14 PM
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 08:57 PM
ECC83 - Long Plate vs Short Plate poynton Tubes / Valves 16 17th February 2008 07:42 AM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 07:40 AM
Copyright İ1999-2017 diyAudio
