parafeed - Gyrator vs CCS anode load
Old 21st November 2010, 04:00 PM   #21
adamus is offline adamus  United Kingdom
dont know until i build it..
It simulates very much like a choke (a big one at that!) but the proof will be in the making and listening.
You can easily improve the PSRR, just stick a v reg infront of it. I am using the salas hv shunt > CCS (soon to be gyrator) > parafeed edcor.
Old 21st November 2010, 04:38 PM   #22
bigwill is offline bigwill  United Kingdom
Originally Posted by Bigun View Post
How does this gyrator design compare with using a choke load ?
Likely to have better bandwidth at either end, lower output impedance if the Mu output is used, better PSRR, adjustable quiescent voltage if needed....
Old 21st November 2010, 08:34 PM   #23
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by bigwill View Post
Likely to have better bandwidth at either end....
that's entirely possible, unfortunately,I've discovered that 15kHz and above is no longer audible to me
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 21st November 2010, 11:25 PM   #24
athos56 is offline athos56  United States
athos56's Avatar
Yeah, you and me both, darn 357 magnums. I guess we get to save money on output transformers though ...
Athos
Old 22nd November 2010, 03:11 AM   #25
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
Wait - This will limit you to 0.7v on the gates due to the forward voltage....
Edit: Ignore me, back to back is not anti-parallel
The DN2540 is rated for +/- 20V gate-source but at normal operating temperatures saturates at about 0Vgs, so a single 15V zener connected with it's anode to the DN2540 gate (as you would a P-channel) works fine for protection.
PS Another option for driving headphone or speaker loads is this balanced current totem pole push-pull circuit using a gyrator. The zener is shown as well as a nice cascode.
Another big difference between the Gyrator/CCS and choke or series feed OPT is the need for higher B+ and consequent dissipation in the active load.
Old 22nd November 2010, 03:50 PM   #26
ok here is a cascode version with dn2540. any improvements welcome.
Old 22nd November 2010, 04:37 PM   #27
iko is offline iko  Canada
iko's Avatar
Another idea for the gyrator, which I borrowed from Anatoliy. I have built this headphone amp a few days ago and have been listening to it; I think the sound is very good, very dynamic, smooth, no lack of bass, nice full mids. The autoformers I got from a surplus shop for a few dollars. These are the type of line matching transformers used in store ceiling speakers.
I should add that I personally prefer using the mje350, since it's easily available at local shops and can get them easily. I doubt it'd make a difference in sound, when compared to using a dn2540. But that is just a guess.
Old 22nd November 2010, 04:37 PM   #28
Sheldon is offline Sheldon  United States
Looks fine to me. Since your gate is driven by the plate supply, I think protection diodes aren't necessary. A short from output to ground would be a problem, but that should be easy to avoid.
BTW, with the cascode, a low voltage JFET is an option for the bottom device.
Sheldon
Old 22nd November 2010, 04:39 PM   #29
I am just this minute drawing up a similar version (but with much smaller cap and a pnp cascode). I'll sim it to make sure no boo boos.
Old 22nd November 2010, 04:42 PM   #30
iko's Avatar
Sheldon
Indeed, I have made an excellent CCS using the dn2540 in the upper position, and a 2sk170 in the lower position. For higher current one can either parallel 2sk170s, or use a higher Idss jfet.
parafeed - Gyrator vs CCS anode loadHide this!Advertise here!
New PNP HV tranny for anode CCS richwalters Tubes / Valves 12 8th November 2010 11:35 AM
Rod Coleman CCS/gyrator help zigzagflux Tubes / Valves 14 7th March 2010 12:40 AM
CCS or V.REG for OP anode pointy Tubes / Valves 0 20th January 2010 12:25 PM
chocke anode load, please explain me.. inertial Tubes / Valves 7 20th February 2009 12:47 PM
LL1673 as anode load? walkwalk Tubes / Valves 1 13th July 2005 03:04 PM
